Whatnow Posted June 24, 2013 Share Posted June 24, 2013 I was driving down the road, turned on the defroster and and overwhelming coolant fumes filled the car. The car didn't get hot, I can't find any leaks and I've owned the car for a month and a half and never had this problem with the defroster at all. I've never had to mess with hvac stuff stuff so I'm looking for suggestions. It's an 07 legacy 2.5 non-turbo.. Link to comment Share on other sites More sharing options...
Whatnow Posted June 24, 2013 Author Share Posted June 24, 2013 Sorry I can't type well well Link to comment Share on other sites More sharing options...
That Guy 2-1 Posted June 24, 2013 Share Posted June 24, 2013 I suspect heater core, if it is you may even notice an oily film on your windshield Link to comment Share on other sites More sharing options...
cschneider Posted June 24, 2013 Share Posted June 24, 2013 I second the heater core. I've had heater cores go and never did see any leakage until I started pulling carpet. Link to comment Share on other sites More sharing options...
Xplosivo1 Posted June 24, 2013 Share Posted June 24, 2013 I 3rd the heater core, look/feel around on the carpet up under the glove box and under the pedals, You will probably find your leak. Once you get your heater core replaced, shampoo the carpets with a 75/25 mix of vinegar and water. Link to comment Share on other sites More sharing options...
Whatnow Posted June 26, 2013 Author Share Posted June 26, 2013 Thanks for the input. I did check the carpet when it first happened and it felt ok but it might have been too soon. Link to comment Share on other sites More sharing options...
Whatnow Posted June 26, 2013 Author Share Posted June 26, 2013 Just checked again.. no wet carpet but the fumes aren't aren't as strong as they were initially. Coolant levels're good.. Guess I'll wait and see what happens Link to comment Share on other sites More sharing options...
