Cody480 Posted June 18, 2013 Share Posted June 18, 2013 So I'm trying to research about this with my 2007 lgt. I have the auto ac system and the6 disc changer, i really don't desire to change the head unit so how to i get the two audio cables that transfer the frequencies to the amp? Are they already in the back of the unit? Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Blue Shark Posted June 22, 2013 Share Posted June 22, 2013 You would want to try to change the head unit, it will sound like garbage if you don't change it. Link to comment Share on other sites More sharing options...
Theheatfan33 Posted June 22, 2013 Share Posted June 22, 2013 ^ In order to do that he has to buy the jdm double din kit which ain't cheap. Link to comment Share on other sites More sharing options...
Blue Shark Posted June 22, 2013 Share Posted June 22, 2013 I was going to link that up, it's like $500.00, supposedly it takes almost 5 months to get to you also. A place here in Utah called Car Concepts offered to create a custom dash when I was looking into a LGT. Link to comment Share on other sites More sharing options...
Theheatfan33 Posted June 22, 2013 Share Posted June 22, 2013 Really? A custom dash wth the automatic climate control? Sounds interesting. Link to comment Share on other sites More sharing options...
Cody480 Posted June 22, 2013 Author Share Posted June 22, 2013 Ya I'm really don't it too be either A. Ridiculously expensive or B. Terrible quality and a lot of splicing and still rather expensive Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Blue Shark Posted June 22, 2013 Share Posted June 22, 2013 They said they would rather do that than try to ship in the JDM thing that sometimes won't even ship, they tried ordering one and never received it to test. Link to comment Share on other sites More sharing options...
Chicken Freak Posted July 19, 2013 Share Posted July 19, 2013 if you dont want to get a head unit you could get a hi/low converter that switches speaker wires to rca cables so you can add an amp. you will still need a amp wiring kit for the amp also. keep in mind as i always say you stereo is only as good as your weakest component. Link to comment Share on other sites More sharing options...
rice_rocket Posted July 19, 2013 Share Posted July 19, 2013 ^ ^^ ^ This, it has been posted a bunch of times, even by myself. RCA convertor will get you signal out of the rear speakers to an amp. Use power wires from your stereo to turn on the amp. Not a competition setup, but it'll do if you just want to add a little more bass. Link to comment Share on other sites More sharing options...
Moddiction Posted August 3, 2013 Share Posted August 3, 2013 The jdm double din is very easy to get. I ordered it and received it within 4 days from the time I ordered. WWW.MODDICTION.COM Moddiction Stainless steel and Titanium shift knobs. Drivetrain, suspension, brakes, exhaust, cooling, fuel, gauges+MUCH more! Link to comment Share on other sites More sharing options...
powersr8810 Posted August 9, 2013 Share Posted August 9, 2013 My input on the converter... I bought the Audio Control LCQ-1 and was not impressed. I ran a sub amp and an amp for the speakers off of it and got basically nothing from my subs which I know can hit very hard. I'm in the process of just installing a single DIN in the cubby as silly as that will look. So if you go the converter route, I suggest you stay away from the Audio Control unit. Link to comment Share on other sites More sharing options...
