mattcornelison Posted June 6, 2013 Share Posted June 6, 2013 My rear passenger side makes a squeaking sound when turning and hitting bumps. I can hear with the windows up and it sounds a little different no clunking though. I removed the tire and took a look the bushing on the upper link attached the sub frame was shredded but when shaking the arm it wasn't loose(#17 in diagram attached is the arm and 18 is the bushing). I sprayed it with lube and the squeaking stop for like 2 weeks. I'm about to buy the bushing but need a second opinion. here is the of a video of noise while I am pressing down on the bumper. VIDEO thanks Link to comment Share on other sites More sharing options...
gear_monkey Posted July 28, 2013 Share Posted July 28, 2013 Did you ever resolve this? My car is doing same thing. I had a friend put it up on a lift and be says my upper control arm bushings are done. Link to comment Share on other sites More sharing options...
