Screamin Posted May 31, 2013 Share Posted May 31, 2013 Besides the Whiteline bushing being poly and the factory bushing being rubber, what are the differences? Both seem to do the same thing, right? I just find it hard to spend $160 on the Whiteline kit if I can buy a new factory bushing for $7 or so and $10-$15 on a cam bolt kit. Any info would be great because I will be lowering my car soon along with new shocks, end links, top hats and such. Yes, I know the poly bushing will last much long and not wear out like the factory rubber bushing plus the poly being stiffer. Link to comment Share on other sites More sharing options...
boxkita Posted May 31, 2013 Share Posted May 31, 2013 if lowering your car, then you'll need more parts, too - bump steer kit. Sticking with one maker for your bushings tend to give you a more cohesive ride, tho, harsher. Poly is stiffer with a harsher ride (you'll feel every bump) Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Screamin Posted May 31, 2013 Author Share Posted May 31, 2013 I read that if you do not lower the Legacy more than 1" than a bump steer is not needed. I plan to keep it at 1" with some Epics or H-Techs. Yes, I know poly is more harsh, I've had a very moddified '01 Camaro SS that had poly motor mounts and trans mount...I went back to rubber because it was too much. I had to replace them about once a year though because I kept ripping them. Link to comment Share on other sites More sharing options...
Dbl_D718 Posted June 1, 2013 Share Posted June 1, 2013 I read that if you do not lower the Legacy more than 1" than a bump steer is not needed. I plan to keep it at 1" with some Epics or H-Techs. Yes, I know poly is more harsh, I've had a very moddified '01 Camaro SS that had poly motor mounts and trans mount...I went back to rubber because it was too much. I had to replace them about once a year though because I kept ripping them. I honestly had some bump steer on the stock suspension. I'm lowered with Epics now and the bump steer is definitely more noticeable. Just FYI. You don't need the bump steer kit, but it'd be worth while. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
Screamin Posted June 1, 2013 Author Share Posted June 1, 2013 Thanks for your input, I'll highly consider buying that kit. Is Whiteline the only company making a bump steer kit? I'd still like to know about my original question though. Link to comment Share on other sites More sharing options...
boxkita Posted June 1, 2013 Share Posted June 1, 2013 I'd thought you answered your own question. Your last car was too stiff. If the stiffness bothers you, go OEM and save your money. It will keep the smooth lgt ride. If you want to tighten things up a bit, the WL bits are a good upgrade. WL is good stuff and covers nearly every suspension part on an lgt. Build my car Boxkita Track days Link to comment Share on other sites More sharing options...
Screamin Posted June 1, 2013 Author Share Posted June 1, 2013 Having a big cam and a 6 speed manual with poly mounts vs only one poly bushing on each side on the suspension is a bit different. If I was swapping out all rubber bushings with poly then I can see it being something I wouldn't like. Link to comment Share on other sites More sharing options...
