frank_ster Posted November 14, 2013 Author Share Posted November 14, 2013 the tranny is still working perfectly .. cant wait for snow .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
RooTBeeR Posted November 14, 2013 Share Posted November 14, 2013 in for vids "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
frank_ster Posted December 16, 2013 Author Share Posted December 16, 2013 well the 4wd definitely works. pulled out of a snow bank with a 1500 lb trailer dragging behind with no problem what so ever. Â but the logic of the center differential clutch seems to be different than what i thought. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 17, 2013 Share Posted December 17, 2013 how so? "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
frank_ster Posted December 17, 2013 Author Share Posted December 17, 2013 It doesn't always engage when i would expect it to.. Â i dont know if its a problem specific to my car, or thats the way it is. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 17, 2013 Share Posted December 17, 2013 I see. How do you engage or disengage it? "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
frank_ster Posted December 17, 2013 Author Share Posted December 17, 2013 right now its activated via stock. Â a few times i put the front wheels on pavement and rear on ice and the rears simply spun. Â but playing in the snow the fronts are definitely engaged. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 17, 2013 Share Posted December 17, 2013 Hmm, well I have no idea how the center diff works. Located in the trans, right? "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
frank_ster Posted December 17, 2013 Author Share Posted December 17, 2013 ^ it works like the dccd on sti's when in auto mode.  it works on a speed vs engine load map. or at least what the manual says.  more engine load more lock more speed less lock. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 17, 2013 Share Posted December 17, 2013 But mechanically its some valves and clutches? "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
frank_ster Posted December 17, 2013 Author Share Posted December 17, 2013 ^ yes. there is hydraulic pump 12 volt control solenoid witch control fluid that pushes on a piston that squeeze clutches. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
RooTBeeR Posted December 17, 2013 Share Posted December 17, 2013 Did you mention before that the clutches don't hold as well as you had hoped? "Build" Thread <--Link (OLD) '05 EJ255 now a '13 EJ257 Bottom End w/D25 heads (NEW) Forever Slow [sIGPIC][/sIGPIC] Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 17, 2013 Share Posted December 17, 2013 The factory service manual explains it really well, is an interesting read [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
frank_ster Posted December 17, 2013 Author Share Posted December 17, 2013 Did you mention before that the clutches don't hold as well as you had hoped? well thats what i'm talking about .. untill yesturday i thought it was going to be a peice of shit. but its totally fine the front wheels are getting all the power they need. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 17, 2013 Share Posted December 17, 2013 If you put it in manual 1st gear, that center should lockup as hard as it's ever going to. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
frank_ster Posted December 17, 2013 Author Share Posted December 17, 2013 (edited) it doesnt .. some thing changed at some point. i feel as if it used to do so. but now it doesn't .. not sure if tcu issues or hydraulic issue. Edited December 17, 2013 by frank_ster Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
ClimberDHexMods Posted December 17, 2013 Share Posted December 17, 2013 Those center lockup frictions get worn, maybe that's it? They see the most dynamic friction of any clutch pack, and they are neither big or many. [CENTER][B][I] Front Limited Slip Racing Differentials for the 5EAT now available for $1895 shipped, please inquire for details! [/I][/B][/CENTER] Link to comment Share on other sites More sharing options...
frank_ster Posted December 17, 2013 Author Share Posted December 17, 2013 (edited) i changed them. and no difference what so ever. but it seems like an intermittent issue.  i checked the piston for travel and leaks and it was fine.  the gasket is good.  what would be left is putting a gauge in the test port. Edited December 17, 2013 by frank_ster Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
mrp669 Posted January 27, 2018 Share Posted January 27, 2018 (edited) Did you ever sort the intermittent center diff slippage? Does the driveshaft handle the abuse? Edited January 27, 2018 by mrp669 Link to comment Share on other sites More sharing options...
frank_ster Posted March 16, 2019 Author Share Posted March 16, 2019 drive shaft yes.. rear diff no .. Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
Kozy Posted March 17, 2019 Share Posted March 17, 2019 Does the lack of a centre diff cause issues during turns when AWD is engaged? Link to comment Share on other sites More sharing options...
frank_ster Posted March 17, 2019 Author Share Posted March 17, 2019 Currently no. As it doesn’t transmit a lot of torque to the front wheels it’s exactly like stock as the transfer clutches are behaving the same. You can notice a bit of bind up in stock form when you put in manual 1 and turn the wheel all the way hold brakes and give throttle. The inside rear wants to skid. The way it currently is ithe front wheels are strong enough to spin on gravel , the transfer clutches don’t seem to get full pump pressure ever so a spring change can send more torque to the front wheels.  When it’s off and driving on snow or ice it’s quite hard to make a corner ! Now that's thinking out of the boxer! fyi all 05 + legacy's have built in code reader Link to comment Share on other sites More sharing options...
FlatFourAutomotive Posted October 14, 2019 Share Posted October 14, 2019 (edited) Exploded my center diff launching too hard... "Fixed" it by making the car rwd only(no center diff gears or clutches) / welded shafts together. Front axles are still in( for speedo to work.) Edited October 14, 2019 by FlatFourAutomotive Link to comment Share on other sites More sharing options...
