Pinsk18 Posted May 24, 2013 Share Posted May 24, 2013 I know this has probably been covered before, but I cant find anything on it. My center driveshaft bearing on my 98 outback is destroyed. I found a replacement kit online. Here: www.torquesolution.com/Subaru-Sti-Drive-Shaft-Support-Bushings-p/ts-su-dsb.htm Will it work!!?? Please let me know. Thanks. Link to comment Share on other sites More sharing options...
mungewell Posted May 24, 2013 Share Posted May 24, 2013 This post covers all you need to know. http://legacygt.com/forums/showthread.php/legacy-2-5gt-center-differential-bearing-swap-204445.html?t=204445 Note: center diffs are different between phase 1 and phase 2, but I think the bearing set up is the same. Link to comment Share on other sites More sharing options...
johnegg Posted May 24, 2013 Share Posted May 24, 2013 i would buy a used drive shaft. no question it would work. http://www.car-part.com put in zip and sort by distance. Link to comment Share on other sites More sharing options...
