teo420 Posted May 17, 2013 Share Posted May 17, 2013 I want to wire in amp and sub to the stock cd I know I will need to modify quite a bit but I need help of where to purchase and what to purchase also planning to wire in a ipod/phone plug while everything is in bits but thats separet issue and I have all the info on that anyway anyone tried to wire in iphone charger? i just wanna get rid of all the loose wires and have aux sockets clear Link to comment Share on other sites More sharing options...
Dbl_D718 Posted May 17, 2013 Share Posted May 17, 2013 You should try using some punctuation in your posts. There's not much that needs modified to add a sub. Get some LOCs, maybe a forward and reverse harness to make getting your signal wires a little easier. Other than that, it's a typical amp/sub install. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
