Cody480 Posted May 12, 2013 Share Posted May 12, 2013 So I've been searching around for a clutch and have been reading reviews that have been placed. From my research it seems that it doesn't really matter what brand you get there seems to be issues with all brands. Is there any one that thinks if i get a spec that it's worse off than any other. Also everyone says the TOB makes allot of noise, so why don't they replace with factory TOB is there a reason or is it just not a normal practice in the Subaru community? I know with my previous cars everytime a clutch replaced to avoid the noise a oem is used. Is there a reason its not recommended here? Just looking for some "imo" from the community and appreciate any feedback. Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Bochim Posted May 12, 2013 Share Posted May 12, 2013 I think it depends on your power output and what your looking for.? I think it would be safe to say that in almost any car once you change from an OEM setup you can expect some different noises and things. Link to comment Share on other sites More sharing options...
Cody480 Posted May 12, 2013 Author Share Posted May 12, 2013 Yes i know that and expect it fully. I have mainly bolt ons and bnr 16g currently being tuned by dave @ cryo. I am looking hard at the spec stage 3 cause it seems people dont have much problems with them i guess. So if i were to get it is the stock flywheel good with resurface, and if i use a OEM TOB will there be any issues with functionality? Because with spec if it works as good as others claim you really can't beat the price. Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Bochim Posted May 12, 2013 Share Posted May 12, 2013 Alot of people do complain about the TOB. After i put my CMFX350 in i thought mine was singing like other people on here have talked about, but after i looked into it the slave rod is moving slightly against the fork from the engine vibration. But i dont see why a OEM TOB wouldn't work. Just make sure its the same as the one that comes with the SPEC kit. Link to comment Share on other sites More sharing options...
Cody480 Posted May 12, 2013 Author Share Posted May 12, 2013 Ok sounds good, thanks. Does anyone have anyone have any huge concerns on the spec that i just haven't found before i take the plunge on a lesser known brand? Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Max Capacity Posted May 13, 2013 Share Posted May 13, 2013 IMO you don't need a stage 3 clutch. I have a Spec 2 and the thing is great. I'm making 280whp on a mustang dyno, that reads low. I also have the TSK3 kit and I got that TOB from Mike at http://www.AZPinstalls.com Email him and get a SMFW from a 07-09 Legacy GT and the Spec clutch to match it. I wipe the FW and PP face with acetone to de-grease it before I install and grease the snout on the tranny as well as the end of the input shaft where the pilot bearing rides. Also grease the shaft on the starter where the gear slides. My Spec 2+ clutch which I replaced after 85,000 miles had good bite left in it. I replaced it with the new short block last May. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Cody480 Posted May 13, 2013 Author Share Posted May 13, 2013 I plan to go higher Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Cody480 Posted May 13, 2013 Author Share Posted May 13, 2013 I want to go near 400h/400+tq so i think doing 3 would just be better in the long run Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Max Capacity Posted May 13, 2013 Share Posted May 13, 2013 DD or weekend car ? The 5mt will not be very happy once you put lots of torque thru it everyday. Some have said about 350ftlbs is where you begin to have issues. These cars can be a lot of fun at lower HP. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Cody480 Posted May 13, 2013 Author Share Posted May 13, 2013 Ya it will be a dd for the time being, and if i start to have issues ill have to do the 6mt trans from spec b or sti. Im quite sure im already around 350 tq already. Just waiting to get my tune finished and dyno. Just taking longer than i expected and currently having issues with leaks and such. Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
lingling1337 Posted May 13, 2013 Share Posted May 13, 2013 350tq? What did you get, the 16g Spec B? Link to comment Share on other sites More sharing options...
Cody480 Posted May 13, 2013 Author Share Posted May 13, 2013 16G spec b? Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Max Capacity Posted May 14, 2013 Share Posted May 14, 2013 He's asking, how did you get 350ftlbs out of a 16g ? Is there something your not telling us? I have a vf52, ported heads, 21psi and I'm making 300ftlbs on stock fueling 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
mr.hicksta Posted May 14, 2013 Share Posted May 14, 2013 I have the ACT HD, TSK3 and SMFW. I'm 'only' putting down 265/290, but it would hold up fine with plenty more power. Lots of people seem to be going down the FX350 route now, which has a lighter pedal feel from what I've been told. Aside from Max's experience with the Spec clutch I haven't heard much good about them, but YMMV of course. Link to comment Share on other sites More sharing options...
Cody480 Posted May 14, 2013 Author Share Posted May 14, 2013 I guess my butt dyno could be off. Ill soon know what i do have. But why does he say spec b? Theres no power differences.? Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Cody480 Posted May 14, 2013 Author Share Posted May 14, 2013 I used the highhopesanddreams butt dyno Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
mr.hicksta Posted May 14, 2013 Share Posted May 14, 2013 I guess my butt dyno could be off. Ill soon know what i do have. But why does he say spec b? Theres no power differences.? Sent from my LG-LS970 using Tapatalk 2 I was talking about the Spec brand clutch Link to comment Share on other sites More sharing options...
Max Capacity Posted May 15, 2013 Share Posted May 15, 2013 16G spec b? Sent from my LG-LS970 using Tapatalk 2 Because this, Ya it will be a dd for the time being, and if i start to have issues ill have to do the 6mt trans from spec b or sti. Im quite sure im already around 350 tq already. Just waiting to get my tune finished and dyno. Just taking longer than i expected and currently having issues with leaks and such. Sent from my LG-LS970 using Tapatalk 2 May be that's why he wrot spec B. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
lingling1337 Posted May 15, 2013 Share Posted May 15, 2013 It was a nice way of saying there's no way in God's green earth you're getting 350tq on a 16g. It's sort of a joke on these forums that anything with "spec. B" on it is insanely awesome. Link to comment Share on other sites More sharing options...
Cody480 Posted May 15, 2013 Author Share Posted May 15, 2013 Oh ok got ya... ya well i also have titanium bolts and run straight plutonium, once that flux capacitor gets to 1.21gigawatts ill definitely be passed 350 ft/lbs, who will be laughing then? :what: Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
Cody480 Posted May 15, 2013 Author Share Posted May 15, 2013 But then again i came across this that shows him being very close to 350, close as in not quite but very close. And i have the same mods plus some. So it is possible no?? ::Sorry for not knowing how to quote him from the other thread:: I had my car dyno tuned March 5th. The tuning was done by Bren Tuning. He uses PSI Racing's (Auburn, MA) Dynapack 2000. Set-up: BNR EVO16G Invidia Catless Up Pipe Megan Racing Catless Down Pipe Infamous/Stromung 3" Cat Back AVO Top Mount GrimmSpeed EBCS Stock Air Box & Filter Stock Fuel Pump Stock Injectors Conditions: Mean Temp: 39 °F Average Humidity: 81 Elevation: 531' Prelude to Results: We did somewhere in the neighborhood of 10 pulls on the dyno before it was all said and done. It was pretty evident early on that the injectors and fuel pump weren't going to be able to keep up with the amount of air that this turbo was flowing. The stock fuel system couldn't keep up after 5500 RPM. There is obviously some power being left on the table. Results: Boost: 19 PSI @ 3300 RPM tapering to 16 PSI @ red line (6250 RPM) Horse Power: 291 @ 5300 RPM and staying relatively flat to red line Torque: 322 @ 3100 RPM Conclusion: The car drives awesome. The torque is right there whenever you need it. The turbo is very responsive. My tuner was impressed with how well the BNR EVO 16G was performing, and if he's happy I'm more than happy. ::rubbing my crystal ball:: "are fuel mods in my future?" Sent from my LG-LS970 using Tapatalk 2 Link to comment Share on other sites More sharing options...
idiot4hire Posted May 17, 2013 Share Posted May 17, 2013 You managed more torque then me and I have a sti short block and a vf52 with full supporting mods Link to comment Share on other sites More sharing options...
