barelars Posted April 19, 2013 Share Posted April 19, 2013 Hi, is there anyone here who has tried this on the EJ204(165bhp) engine? Is it recommended to block of the EGR valve in this car? There is also a "plastic electrical turbo" thing on front left side of the engine, does anybody know what this is? I'll try to take a pic later. Thanks in advance =) Link to comment Share on other sites More sharing options...
BrandonspecB Posted April 23, 2013 Share Posted April 23, 2013 Well, I'm not exactly sure of the details of your engine, but if it has AVCS then there is no EGR equipment to remove. The EGR is done internally with valve timing. I think the other thing you are talking about is the air pump. It pumps fresh air into the exhaust during cold start to help light off the cats quicker for better cold start emissions. It can be removed, but requires block off plates to be installed. I pulled my air pump off. There is a write up on this forum I believe. You have to get the block off plates from Infamous Performance. Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted April 23, 2013 I Donated Share Posted April 23, 2013 Well, I'm not exactly sure of the details of your engine, but if it has AVCS then there is no EGR equipment to remove. The EGR is done internally with valve timing. How would AVCS have anything to do with exhaust gas recirculation? Also, the air pump is not plumbed into the exhaust system, AFAIK. I could be wrong about that, though. Link to comment Share on other sites More sharing options...
BrandonspecB Posted April 23, 2013 Share Posted April 23, 2013 How would AVCS have anything to do with exhaust gas recirculation? Also, the air pump is not plumbed into the exhaust system, AFAIK. I could be wrong about that, though. EGR is with valve overlap. Advance the intake cam to overlap more with the closing of the exhaust cam. Air pump is plumbed into the cylinder heads and makes its way into the exhaust stream. Check this out for info about internal EGR: http://drive2.subaru.com/Win05_WhatsInside.htm Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted April 23, 2013 I Donated Share Posted April 23, 2013 You learn something new every day! Link to comment Share on other sites More sharing options...
danci1973 Posted July 20, 2013 Share Posted July 20, 2013 There is an EGR valve on the 2.0R, it's behind the alternator on the intake. I think the 'internal EGR' is just marketing speech... Valve overlap has been around for a long time without variable valve timing, so this type of 'EGR' comes as 'standard' on most cars. D. Link to comment Share on other sites More sharing options...
barelars Posted July 20, 2013 Author Share Posted July 20, 2013 Hi guys. I've tried to block it. Made a nice little plate and all but i got outsmarted by the subie when it sensed that it was blocked and gave me a cel (P0400). Sent from my GT-I9300 using Tapatalk 2 Link to comment Share on other sites More sharing options...
I Donated thefultonhow Posted July 20, 2013 I Donated Share Posted July 20, 2013 Hi guys. I've tried to block it. Made a nice little plate and all but i got outsmarted by the subie when it sensed that it was blocked and gave me a cel (P0400). Try plugging in the valve and ziptying it somewhere instead of bolting it on. Link to comment Share on other sites More sharing options...
