sutter2k Posted August 8, 2005 Share Posted August 8, 2005 I can't find a puncture, but doen't seem to be holding air overnight. Hmm what todo. I was not planning to replace these till after the winter. At the same time, I don't feel like buying a replacement RE92. Considering ---> buy rota boost's & all seasons(falken 512's) for wife's car, put her HTZ II's on my new rims. or buy pzero's and consider her tires and my rims later. Anyone in the market for 3 relatively new RE92's? Matt Link to comment Share on other sites More sharing options...
PhilT Posted August 8, 2005 Share Posted August 8, 2005 Try removing the inflated wheel, then splashing soapy water over it. Check around the seal on the rim and the valve, for bubbles. Once you find where it's leaking from it shouldn't cost much to repair it. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
052.5GT Posted August 8, 2005 Share Posted August 8, 2005 I have had the same problems with my re92's since day one. I now have just shy of 14,000 miles on the car. They (front tires) need to be re-inflated after every 250-300 miles. I just came back from a trip to VA, and the front right was down to 18.5psi, while the left was down to 23psi. I have had them looked at with no solutions. I want to have a good performing tire in the wet & dry without killing me in the winter here in PA. Any input would be much apprieciated. P.s. Anyone notice a surging in the drivetrain while running between 65-70 mph on the highway. I have an Automatic that does this every now and then. Link to comment Share on other sites More sharing options...
godwhomismike Posted August 14, 2005 Share Posted August 14, 2005 Mine all seemed to loose air every couple of hundred miles. They drove me nuts in every way possible, so after 5000 miles with them - I got rid of them. Link to comment Share on other sites More sharing options...
meier motor sports Posted August 14, 2005 Share Posted August 14, 2005 yeah if its not holding air over night then there is a quite significant leak. and it should be fairly easy to find with soapy water. Link to comment Share on other sites More sharing options...
jim malach Posted August 15, 2005 Share Posted August 15, 2005 yea have not driven my car for a week and the tires are low again fu@#$ tires? Link to comment Share on other sites More sharing options...
Guest JessterCPA Posted August 25, 2005 Share Posted August 25, 2005 My right front does the same. Causes a vibration at highway speed. I fill it back up & it goes away. Link to comment Share on other sites More sharing options...
