06LegacyRBP Posted April 6, 2013 Share Posted April 6, 2013 Does this box need to be full like the radiator is? I keep filling my overflow and it dissapears! This tank looks half full so my question does this tank need to be filled up to full? It the tank next to the TMIC on the passenger side. Let me know ya and i will fill it if need thanks! Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted April 6, 2013 Share Posted April 6, 2013 Yes, it's also the highest point of the cooling system. It where you should add you coolant when low or after draining the system. I usually remove radiator cap, fill coolant thru the turbo coolant tank (your pic. in your post) until I see coolant at the top of the radiator. Cap radiator & continued filling until turbo coolant tank is full. Fill radiator overflow tank to "HOT" level. Start car, heater on high & add more coolant to the turbo coolant tank until the air bubbles are gone & won't take anymore coolant. Put the top on the turbo coolant tank. Take car for 5-10 mile drive, let it cool down, check radiator overflow tank level & top off if level is blow the "COLD" mark. The should get the air out of the system. Coolant only disappears when you have a leak or air in the system. Would be checking for both. Mike Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
06LegacyRBP Posted April 6, 2013 Author Share Posted April 6, 2013 Very helpful thanks mike! I don't have any leaks im sure i have air bubbles cuz i can hear water like sound from the cabin...thanks for your input! Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted April 6, 2013 Share Posted April 6, 2013 Park it on a hill or jack up the front end next time you fill it up, it'll help burb some bubbles out before you close it up again Link to comment Share on other sites More sharing options...
