bomberlegacy Posted March 23, 2013 Share Posted March 23, 2013 How is it working for you? When I first installed mine, the belt didn't look like it sat down in the rib channels quite right, but I went with it. Now, my belts chirp, especially when cold. That is not my big issue though, I am not building the right boost with the SC and I suspect the belt is slipping. It is plenty tight, I don't want to over tighten it. I would just put my OEM pulley back on and test, but it was a PITA to get the bolt loose due to having the 4EAT. So..how is yours working? '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
bomberlegacy Posted March 23, 2013 Author Share Posted March 23, 2013 Well I found the hole in the case finally for access to the flywheel. So I'll be swapping to stock tomorrow to test. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
