Jduke Posted August 5, 2005 Share Posted August 5, 2005 Hey, well i was rotating wheels the other day and happened to notice the bushing (I THINK) that is attached to he sway bar looks squished out of the area its supposed to be in. I have not heard anyodd noise but the car does seem to rock a bit over bumps, uneaven road, but as these things usually go I did not notice a problems with the handling untill i saw the bushing... Does anyone have close pic of the front sway bar bushing area, so I can see... Thanks for your time. John D. Link to comment Share on other sites More sharing options...
Xenonk Posted August 5, 2005 Share Posted August 5, 2005 if you have a pic of your own car, then I can tell you if the the bushing is bad or not. Keefe Keefe Link to comment Share on other sites More sharing options...
Jduke Posted August 8, 2005 Author Share Posted August 8, 2005 sheesh, they are ok... i looked again and what I thought was a piece squished out was actually just a little "u" semicircle part of the bushing both sides had this in the same place so I assume they are all set. I have a set of whiteline sways comming the 15th anyhow... Thanks John D. Link to comment Share on other sites More sharing options...
Ridgeracer Posted August 11, 2005 Share Posted August 11, 2005 Get some AVO poly bushings and forget about them. "Gimme mines Balboa...Gimme mines".....Clubber Lang - Mr. T Link to comment Share on other sites More sharing options...
