Part number for Duty C solenoid
Common 4EAT Problems & Solutions
Torque Bind
This is probably the most common 4EAT problem. This is the transmission getting stuck in a 50/50 power split now allowing for slippage in the center diff. Its usually caused by a faulty Duty C solenoid, however can sometimes be cured with a few "drain and fills"
Car is having issues shifting, is it the Duty C, or something else?
the duty c has nothing to do with the auto trans shifting. but there are other solenoids that are involved.
do you have a flashing AT Temp light at start up?
what is your trans doing?
the duty c can be found at http://opposedforces.com/parts .
drill down in your model year, engine, and trans. then look under the auto trans section at the ''extension housing''. it comes a an ''valve assembly'' and you will need 2 identical gaskets for the valve body.
