Just picked this up
Good question. I don't know if has been done or not but what does it envolve? I know it had an oil change and the fuel filter looked new. I checked the transmission and it didn't look or smell that bad everything works. Traded my 92 Celica GT for it. :icon_mrgr
Right on got a good trade then, and welcome...
First off you cars got really low mileages for its age probably gently driven to. IF You already looked at oil and all the things you mentioned, they may have done most for you which is mighty nice. I would inspect all the brakes, rotors, pads and calipers probably grease the caliper slides and check the dustboots. Inspect all the rubber bushings, balljoints, steering rack and tierods, cv joints and boots underneath the vehicle...its good practice to do the differential fluid in front and rear( I do mine every year). Mostly concentrate on consumable stuff like that.
