robot8282 Posted February 20, 2013 Share Posted February 20, 2013 I never know where to post so I'll just stick to the N/A section. I think I read somewhere that the gt rear sway bars will not fit a 2.5i so are there sway bars/endlinks that will fit a 2.5i? (Wagon if that makes a difference) And if so would it actually be worth it? And on a completely different topic, how does one go about removing the front grill? I unclipped the top four brackets but it seems to still be stuck in place. I'd imagine there are more brackets underneath or something but I can't seem to find them. Link to comment Share on other sites More sharing options...
Rahhstah Posted February 20, 2013 Share Posted February 20, 2013 I used this site for grille removal help. Link to comment Share on other sites More sharing options...
bomberlegacy Posted February 20, 2013 Share Posted February 20, 2013 The front swaybar is different between a GT and 2.5i, rear are the same. I'm not sure about sedan vs wagon. There are four snaps on top of the grill and 4-6 small screws on the back. If you have big forearms, you might need to remove the bumper. '08 Legacy 2.5i - hybrid intake - delta 1000 - E85 - magnaflow exhaust Link to comment Share on other sites More sharing options...
JJr Posted February 20, 2013 Share Posted February 20, 2013 I know the Sedan and Wagon GT RSB's are the same, you should add the RSB AVO mounting brackets too ( stock mounts have been an issue) AVO just became available after 3 months too. Installing mine with MOOG endlinks from rockauto.com very beefy and inexpensive in comparison to the $100+ models. Of course if you're planning on tracking the car spend the $100+ Link to comment Share on other sites More sharing options...
