archer1.8 Posted February 13, 2013 Share Posted February 13, 2013 120K Miles Cobb OTS stage 2 for 5,000 miles. 5EAT When I am in 3rd gear (only 3rd gear) and I do a pull from 2500 RPMS to redline, around 4900 RPM the revs stop for a second and then continue. Its like a dead spot. It does not feel like transmission slip. The trans shifts like butter everywhere in any gear. Its just in 3rd gear it has this problem. If I load the engine up however in 3rd gear from around 3,000 RPMS it wont do it. Also if I disconnect the battery, and I do a pull it wont do it, however on the second pull it will. So am i pulling timing, or is the 5eat really showing signs of wear? Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 13, 2013 Share Posted February 13, 2013 can you log or pull learning view?? Link to comment Share on other sites More sharing options...
archer1.8 Posted February 13, 2013 Author Share Posted February 13, 2013 I wish i could. I am using a v1 accessport. I am in the process of reading about vag com cables, tactrix is a little to pricey as of right now. Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 13, 2013 Share Posted February 13, 2013 Yea the Vags work good, its getting romraider to work with your operating system and not having too much "noise" in the system.. I think strizzy may be able to help you out a little better, I think he had a hell of a time with his RR and VAG Link to comment Share on other sites More sharing options...
archer1.8 Posted February 14, 2013 Author Share Posted February 14, 2013 just bought a vag com.......while a wait for it to come...can i use my Torque app to help narrow it down. It shows timing advance, Mass air flow voltage Link to comment Share on other sites More sharing options...
archer1.8 Posted February 15, 2013 Author Share Posted February 15, 2013 been digging around and it seems that my problem is more of a tune issue. I also noticed I have a huge exhaust leak post turbo at the donut gasket. Could this be part of the problem? Vag Com cable is on the way This is not my video but my problem is similar at around 14secs. At 5,000 rpms the revs stop (his stops WAY longer) mine is more of a stutter [ame=http://www.youtube.com/watch?v=NzcgCnW12_U]http://www.youtube.com/watch?v=NzcgCnW12_U[/ame] Link to comment Share on other sites More sharing options...
06silvarubiLGT Posted February 15, 2013 Share Posted February 15, 2013 almost shit myself, then realized kmh.. The timing advance might not be a bad thing to look at in the mean time, it would narrow down if the car is pulling timing Link to comment Share on other sites More sharing options...
archer1.8 Posted February 16, 2013 Author Share Posted February 16, 2013 So the closer i get to redline the lower the.number is,....if ignition timing is pulled the number will jump up correct? Link to comment Share on other sites More sharing options...
archer1.8 Posted March 2, 2013 Author Share Posted March 2, 2013 Plot thickens. I.got.a.p0301 code. My coil is.new.on that cylinder.i plan to.check the plug then swqp injectors.if needed. I also am.only hitting 15psi instead of 17psi. Link to comment Share on other sites More sharing options...
