Custom Trendz Inc. Posted March 3, 2013 Share Posted March 3, 2013 thanks, i started in the middle, and without cutting any of the lip off(other then the end caps off) I warmed up the grill with the heat gun as i tightened the screws around the indent in the middle of the bumper. Also once i had it all mounted i unscrewed each screw, cut the lifted bumper plastic and the lip plastic with a exacto and screwed it back in for a tight fit with the bumper. Link to comment Share on other sites More sharing options...
PaSprinter24 Posted March 3, 2013 Share Posted March 3, 2013 hey custom trendz I kno this forum is about the nasty front lip that ill be sure to be ordering soon but how hard was it to eliminate the yellow from you headlights? Or are they aftermarket which they don't seem to be Link to comment Share on other sites More sharing options...
Custom Trendz Inc. Posted March 3, 2013 Share Posted March 3, 2013 hey custom trendz I kno this forum is about the nasty front lip that ill be sure to be ordering soon but how hard was it to eliminate the yellow from you headlights? Or are they aftermarket which they don't seem to be You will have to take off bumper, mounts under headlight, grill, and then bake the headlights in an oven for a few minutes(5-8) at 250 degrees fahrenheit. There is a diy on this forum. Just search "clearing headlights." Please look up the thread first because there is screws you need to remove in the headlight housing and the bulbs. Sent from my DROID RAZR using Tapatalk 2 Link to comment Share on other sites More sharing options...
