McMullen34 Posted February 6, 2013 Share Posted February 6, 2013 My 05 subaru legacy 2.5i non turbo idles normal when it is in nutral or park but when i put it in drive it drops to like 500-600rps and shuts off.Even on level ground. I recent put new plugs new head gaskets and thermostat and thermostat gasket. Link to comment Share on other sites More sharing options...
Soulace Posted February 7, 2013 Share Posted February 7, 2013 Sounds like the ECU just needs to be reset. Did you take it to a shop for the work, or DIY? Link to comment Share on other sites More sharing options...
McMullen34 Posted February 7, 2013 Author Share Posted February 7, 2013 I had the ECU reset at a garage and it hasn't changed it? I'm being told it might be a vacuum leak? Link to comment Share on other sites More sharing options...
Oregon OBXT Posted February 7, 2013 Share Posted February 7, 2013 I had the ECU reset at a garage and it hasn't changed it? I'm being told it might be a vacuum leak? Very likely. Either a hose is off, clamp is loose, or the manifold gaskets were re-used. Link to comment Share on other sites More sharing options...
