mmarton Posted February 4, 2013 Share Posted February 4, 2013 The wire accidentally pulled out of the clip. I noticed under the outer insulation that there's a thin layer of woven wire surrounding a core wire. I'd like to splice a wire to lengthen it. Is there another wire inside the core? Do I just remove some of the outer insulation? Thanks for your help. Link to comment Share on other sites More sharing options...
mmarton Posted February 6, 2013 Author Share Posted February 6, 2013 Figured out a solution. Rather than do a splice, I bought a new antenna harness with a Motorola female end and a Motorola-type solderless jack that I'll attached to the cable coming out of the radio. Link to comment Share on other sites More sharing options...
Mr.EMan Posted May 4, 2013 Share Posted May 4, 2013 Just had a similar problem. I bought a used 2007 radio, and they just snipped the antenna cable. What I ended up doing was soldering the part with the connector from my 2005 radio to the 2007 radio. I cut to the conductor and soldered them together. I wrapped this in electrical tape. Then I tried pushing the braided ground wire back together, but this wasn't a connection. I had some aluminum tape that I then used for the braided wire. This gave it the conductivity that it needed. I used electrical tape over everything instead of heat shrink tubing to give in some strength. Link to comment Share on other sites More sharing options...
