97LegaGT Posted January 29, 2013 Share Posted January 29, 2013 Does anyone else find that when checking oil the level, on the one side of the dipstick the level reads around a 1/4 inch higher than the other? Mine has always done this and I'm not sure what reading to go by. I usually aim to have the one side read full so the other side reads half, would this be optimal? Link to comment Share on other sites More sharing options...
SCASEYS Posted January 29, 2013 Share Posted January 29, 2013 ____/_____ ......./........... angle of dipstick? I donated to LegacyGT.com which allows me to have this nifty signature. If anything SCASEYS posts ever becomes a sticky i'm gonna light this whole place on fire Link to comment Share on other sites More sharing options...
johnegg Posted January 29, 2013 Share Posted January 29, 2013 think about it, how can the oil level be higher than the lowest mark? maybe there is a small dimple or low spot in the pool of oil in the pan?? not likely. the lowest mark is the correct mark. when checking the oil, wait for a bit so any oil left in the ''tube'' by the dipstick has time to drip back down in to the pan. Link to comment Share on other sites More sharing options...
colby Posted January 29, 2013 Share Posted January 29, 2013 i think the way the tube bends it causes it to smear oil on the stick. check in the morning before you drive for best results. as long as you keep it above the min you will be fine. Link to comment Share on other sites More sharing options...
97LegaGT Posted January 29, 2013 Author Share Posted January 29, 2013 Perfect thanks colby and scaseys. That's what I figured, just thought I'd throw it up here because I just put in some castrol high mileage and I was curious. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 30, 2013 Share Posted January 30, 2013 i rarely have a reading on my dip stick when i check it, i just tossed oil in till it reached the stick, never was more then a qaurt or 2 from full so dont sweat it. these motors could probably run on 2 quarts, one quart at idle maybe. BNR18g on 93oct Link to comment Share on other sites More sharing options...
spooln30 Posted January 30, 2013 Share Posted January 30, 2013 ^ What? That maybe the way you work on your car but dont get advice like that to people who are seeking the correct answer. Try and drive you car around with 2 qts and see how long it will last. If you think about it 2qts is probably barely enough to cover the filter and all of the engines oil galleries. Op: this happens to a lot of cars. This happens on our engines because our dip sticks go into the oil pan on an angle. So use the higher of the two readings and top off from there. On my 2.5 with a filter it takes 4.2 qts. It also takes longer for our engines to fully drain back the oil into the pan due to it being a H engine so wait like 5 mins to recheck after an oil change or you'll over fill. Link to comment Share on other sites More sharing options...
97LegaGT Posted January 30, 2013 Author Share Posted January 30, 2013 Thanks spooln, I figured it was due to the angle but half on one side and full on the other seemed a little extreme. The PO had the oil over the full mark which caused excessive oil leakage thar would burn off on the exhaust. I'm hoping the castrol high mileage will help with the leakage I have now because I don't want to put much more money into it. The less money that goes into my subi the more I can put into my 91 talon (oh and university). Link to comment Share on other sites More sharing options...
spooln30 Posted January 31, 2013 Share Posted January 31, 2013 Yeah it's weird but it's just the way it is. When I had a 7mgte in my Supra the dipstick was so hard to read when the oil was clean it was frustrating at times. Link to comment Share on other sites More sharing options...
