stalling
I was looking around a little bit and haven't found anything does anyone else's lgt stall when you come to a stop, or even going down the highway if i hold the clutch and and let it go to idle it will just die. i just put brand new gpower plugs in it and that didnt fix the problem also the wires look new too. It doesnt die all the time but probably 25% of the time it will. any info on this would be greatly appreciated thanks!
Well if it was the MAF then when you pressed the gas it wouldn't want to go anywhere so clean it but I doubt it's your problem. I would lean towards your IAC, the EGR valve or a vacuum hose/intake leak somewhere. Our IAC valves are door type valve and they've been know to get carbon causing them no to fully close or open. I would remove this as well and clean it really good with some carb spray. If the problem persists then test your egr valve and egr components. GL.
