ChrisC92 Posted January 22, 2013 Share Posted January 22, 2013 Hey I really want to convert to a 6MT transmission, but im not sure which will fit to my car. I have found a few transmissions from Foresters from year 2004-2008. Link to comment Share on other sites More sharing options...
Drift Motion Posted January 22, 2013 Share Posted January 22, 2013 damn even the forester came with 6MT in Europe?! Link to comment Share on other sites More sharing options...
ChrisC92 Posted January 22, 2013 Author Share Posted January 22, 2013 There are actually 2 Foresters on the scrapyard database here, but the transmissions is not usable.. Link to comment Share on other sites More sharing options...
subikid90 Posted January 22, 2013 Share Posted January 22, 2013 It will fit. Not sure what driveshaft you will need though. -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
SpecBamf41 Posted January 22, 2013 Share Posted January 22, 2013 i hear the 4 eat drive shaft fits.. BNR18g on 93oct Link to comment Share on other sites More sharing options...
ehsnils Posted January 22, 2013 Share Posted January 22, 2013 damn even the forester came with 6MT in Europe?! All diesels comes with 6MT, and quite a few gasoline cars too came with either 5MT, 5MT with dual range or 6MT depending on model year since they provide a better fuel economy, especially compared to the 4EAT. Just check that the gearing of the rear diff is the same as for the new gearbox front diff. To be on the safe side you should make sure to get the driveshaft too if you get from a newer vehicle. If you are lucky it's just a drop in, if not you may need to adjust the length of the shaft. A decent welder should be able to fix that for you. (I did that on a Volvo once where I mounted an overdrive gearbox and had to have a shorter driveshaft.) Maybe you can find something of use in this thread too: http://legacygt.com/forums/showthread.php/wants-see-my-vacation-pixi-6216p23.html Link to comment Share on other sites More sharing options...
