the pizza Posted January 13, 2013 Share Posted January 13, 2013 Can I run stock '08 17" Legacy rims on an '05 Legacy? they look like they match up, as far as specs, but I just wanted to make sure. Link to comment Share on other sites More sharing options...
jasejase Posted January 13, 2013 Share Posted January 13, 2013 yes... assuming brakes are stock and no curve balls of that nature my wife has an 05 leggie with 2009 leggy wheels. Link to comment Share on other sites More sharing options...
the pizza Posted January 13, 2013 Author Share Posted January 13, 2013 thanks for the knowledge! everything is stock so i think i'm good. ima have 05 wheels up front with 08s in the rear. mismatched but I think it will look dope. nice spec B by the way;-) Link to comment Share on other sites More sharing options...
jasejase Posted January 13, 2013 Share Posted January 13, 2013 Thanks! Make sure the rolling diameters are pretty much identical (taking into account the wheel and the tire). An awd car needs to have the exact (more or less) same diameter on each corner. There are calculators online. You will need to find the tire size and know the wheel size obviously. Link to comment Share on other sites More sharing options...
Drift Motion Posted January 13, 2013 Share Posted January 13, 2013 05 legacy/non gt wheels are 16", so you probably have the 205s instead of the 215s there will be slight difference in overall diameter, but probably not enough to make a difference Link to comment Share on other sites More sharing options...
the pizza Posted January 14, 2013 Author Share Posted January 14, 2013 both rims are 17x7. at least thats what the info said on the ebay page. the only difference was one had an offset of 50 and the other 55. I'm not sure if that's going to make a ton of difference? Link to comment Share on other sites More sharing options...
Drift Motion Posted January 14, 2013 Share Posted January 14, 2013 not enough both should have the same offset of either 55 or 53... Link to comment Share on other sites More sharing options...
the pizza Posted January 15, 2013 Author Share Posted January 15, 2013 how come? Is it a clearance issue with the wheel housing? Link to comment Share on other sites More sharing options...
Drift Motion Posted January 15, 2013 Share Posted January 15, 2013 I meant not enough to make a difference...lol Link to comment Share on other sites More sharing options...
