shadoobie Posted January 4, 2013 Share Posted January 4, 2013 Can I fit 205/50 17 on stock rims on a very lowered 05 wagon? 225/45 17s worked just fine in the summer, but 205/50 is even taller right? any advice or help greatly appreciated! Has anyone run these on a wagon? A lowered wagon? Link to comment Share on other sites More sharing options...
krzyss Posted January 4, 2013 Share Posted January 4, 2013 Why do you think 205/50 is taller than 225/45? Krzys Link to comment Share on other sites More sharing options...
shadoobie Posted January 4, 2013 Author Share Posted January 4, 2013 205 x .50 = 102.5 225 x .45 = 101.25 102.5 is greater Link to comment Share on other sites More sharing options...
monkonmonk Posted January 4, 2013 Share Posted January 4, 2013 205 x .50 = 102.5 225 x .45 = 101.25 102.5 is greater So, the tire would be 2.5 millimeters taller. But, tire variation between brands, model, etc. would eat up the 2.5mm. Link to comment Share on other sites More sharing options...
Ellesedil Posted January 4, 2013 Share Posted January 4, 2013 Only 1.25mm, actually. Also, is this going on the same width rim as the summers? If you're summers are pretty square on the rim, cutting 20mm from the width of the tire will stretch them a bit, which will probably eat the difference all by itself. Link to comment Share on other sites More sharing options...
krzyss Posted January 4, 2013 Share Posted January 4, 2013 In short, their circumference is virtually identical. Check manufacturer's specs and you will find that they are very, very close. Krzys Link to comment Share on other sites More sharing options...
shadoobie Posted January 6, 2013 Author Share Posted January 6, 2013 thanks guys...I'm going with 205/50! Link to comment Share on other sites More sharing options...
digger47 Posted January 11, 2013 Share Posted January 11, 2013 I run 205/50/17 snow tires on my wagon. I usually put the stock suspension back on, but our winters have been mild in Ohio, so I still have my bilsteins with swift springs and never had an issue. Link to comment Share on other sites More sharing options...
K2e2vin Posted January 11, 2013 Share Posted January 11, 2013 Only 1.25mm, actually. Also, is this going on the same width rim as the summers? Monkonmonk was right, it'd be 2.5mm. 1.25mm is just the sidewall, OD/height would be rim diameter+both sidewalls. I went basically to what you went(225/45 summers to 205/50); even though I'm at stock height I didn't really see a difference(I had them next to each other to make sure). Link to comment Share on other sites More sharing options...
Ellesedil Posted January 15, 2013 Share Posted January 15, 2013 Monkonmonk was right, it'd be 2.5mm. 1.25mm is just the sidewall, OD/height would be rim diameter+both sidewalls. Good call. I didn't realize he was talking about the total height. Link to comment Share on other sites More sharing options...
shadoobie Posted January 17, 2013 Author Share Posted January 17, 2013 2" snow + AWD + brand new snow tires + 300whp = one fun commute!!! Link to comment Share on other sites More sharing options...
