PINESMOKER Posted January 2, 2013 Share Posted January 2, 2013 So my neighbor just gave me a 98 Subaru legacy gt 2.5 5spd. He said it has tranny problems. So he says it hard to get in gear and your lucky if you can find them if you do. So my question to you guys and gals. Are tranny problems common? Is there something he might over looked? Linkage throw out Anything I should be testing or checking before ripping the trans out? Any thing helps since I'm new to Subaru's Link to comment Share on other sites More sharing options...
jp71ss Posted January 2, 2013 Share Posted January 2, 2013 Might check the bushings on the shifter. The way they look that seems like it could make it difficult to get into gear. Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 2, 2013 Share Posted January 2, 2013 Check tranny fluid level if you haven't already. Link to comment Share on other sites More sharing options...
spooln30 Posted January 5, 2013 Share Posted January 5, 2013 Could be quite a few things. Bad synchros inside the trans, worn shift forks inside the trans, a weak clutch slave or master cylinder, weak pressure plate springs or throw-out bearing or worn shifter bushings. Start with the cheapest and easiest, the shifter bushings. GL. Link to comment Share on other sites More sharing options...
PINESMOKER Posted January 5, 2013 Author Share Posted January 5, 2013 So started to really check this trans out and found a lot of play in the front carrier I think a bearing failed. Trans oil is black and burnt with a lot of metal flakes...another 5SPD bites the dust. Link to comment Share on other sites More sharing options...
