Drogos Posted December 7, 2012 Share Posted December 7, 2012 opens/closes just fine, seals properly, no symptoms other than 2 loud clunks when going up and 1 when going down. ALways the same way in exact same moment. Right in the beginning of operation and at the very end when going up. Any thoughts ??? Link to comment Share on other sites More sharing options...
nstg8r Posted December 8, 2012 Share Posted December 8, 2012 When I had my windows tinted, the installer heard that thump and was like, WTF?! My Subaru seems to make a few strange and somewhat random noises that I guess are normal (i.e., shift lock, abs test, etc.). Link to comment Share on other sites More sharing options...
FJuan Posted December 8, 2012 Share Posted December 8, 2012 The most common reasons: 1) Window regulator (window track) is loose. Pop off the door and tighten bolts. 2) Motor gear is loose on the regulator. Tighten motor bolts. 3) Motor gear is missing/worn teeth. Pull motor off and inspect motor gear. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
