Screamin Posted December 7, 2012 Share Posted December 7, 2012 I noticed last weekend my rear defrost isn't working. I just figured it was a loose connector. Today I took the time to start looking at the issue. I took the c pillar covers off and seen the connectors are hooked up. I broke out the multimeter and started checking it out. I checked every-which-way you can think of for voltage. Power wire it getting plenty of power, ground wire is good, filaments in the window are good. When I hook up the ground wire to the filament connector, that's when it does not work, no voltage. I figured something was wrong with the two connectors when connected so I made my own ground. I drilled a small hole in the c pillar, sanded the paint off around the hole, wrapped some 14 gauge wire around it, used a male connector crimped and all. Hooked everything up......nothing. No voltage again. WTF? Anyone have an idea? Link to comment Share on other sites More sharing options...
AkumaMax Posted December 7, 2012 Share Posted December 7, 2012 Might be a broken line causing a fault. Link to comment Share on other sites More sharing options...
Screamin Posted December 7, 2012 Author Share Posted December 7, 2012 I tested the window, had the power cable hooked up and checked volts, worked every single time I checked it. Just in case anyone is wondering how I did that. I had the ground cable disconnected, red wire from multimeter on ground connection of window, and black wire from multimeter grounded to car. I used this ground on the car every time and had no issues. Link to comment Share on other sites More sharing options...
Screamin Posted December 9, 2012 Author Share Posted December 9, 2012 No one? Link to comment Share on other sites More sharing options...
Jay12Legacy Posted December 13, 2012 Share Posted December 13, 2012 check with a test light and see if it will light Link to comment Share on other sites More sharing options...
Screamin Posted December 14, 2012 Author Share Posted December 14, 2012 I'll have to find my test light, I haven't used that thing in forever....it's probably because I had electrical issues. Link to comment Share on other sites More sharing options...
Screamin Posted December 14, 2012 Author Share Posted December 14, 2012 I will break out the test light this weekend but I did however check for amps....I couldn't find any. I tested the positive wire, in parallel, to the window. For shits and giggles I tested window to ground. All I seen on my multimeter was 0.00-0.01. I don't know if it's my multimeter or if there really isn't any amps flowing through the system. I even switched around the relay with a known good relay, same outcome. Link to comment Share on other sites More sharing options...
Screamin Posted December 14, 2012 Author Share Posted December 14, 2012 Just found out I did it wrong, supposed to check impedance in series. I'll check it again tonight. Link to comment Share on other sites More sharing options...
