mwiener2 Posted December 26, 2012 Share Posted December 26, 2012 See other thread you posted in My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ragman Posted December 27, 2012 Share Posted December 27, 2012 I'm at stage 3, 91 oct, high flow cat, etc etc. My plates renewal is coming up in Jan. I did a bunch of mobile spot drive bys, and I am hoping I passed! Well, I did not pass the mobile drive by. I received my renewal card in the mail yesterday, and it says emission test required, shit! I have an AVO TMIC, Grimmspeed EBCS, BNR16g, tuned for 19.5 target boost, CNT catted DP. Can I just swap the DP with the OEM stock DP and LEAVE my car stage 3 tuned for the emission test? Or do i need to put on a stock tune, stock boost controller, stock DP, stock TMIC to pass? Link to comment Share on other sites More sharing options...
mwiener2 Posted December 27, 2012 Share Posted December 27, 2012 just the DP My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ragman Posted December 27, 2012 Share Posted December 27, 2012 Cool, thanks Mike! Link to comment Share on other sites More sharing options...
mwiener2 Posted December 27, 2012 Share Posted December 27, 2012 I should rephrase that... Just the DP as long as the rest of it is in good working order. proper tune, no major exhaust/intake leaks (no cracked welds at flanges), O2 sensors are working, etc. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
ragman Posted January 20, 2013 Share Posted January 20, 2013 With the beautiful weather in Denver today and my JAN plate expiration, a PASSING emission test was my goal. I swapped out my CNT DP with my stock downpipe. Damn O2 sensor in my CNT DP was not coming out...not even with the O2 sensor removal tools from Autozone. So, I had to buy an extra O2 sensor from NAPA for $90 to go with my stock DP. I built a low boost map via Accessport Tuner Race. Still running my EBCS, AVO TMIC, and BNR16g, I just turned down my boost down from 19.5 to 14 lbs max boost, which I figured would help, and took it down the emission place. Passed with flying colors... TEST READINGS LIMITS HC GPM 0.0206 1.20000 CO GPM 0.9230 15.0000 NOx GPM 0.0478 1.50000 Went back home and swapped the DP back. Its all kind of a pain in ass dropping the DP on ramps in your driveway. Do-able. But crappy. It sure would be sweet to have one of MWeiners high flow emission friendly cats. Well, at least I'm good now for the next 2 years. Maybe by 2015, the front range will eliminate emission testing. Otherwise, I might just need to invest in one of those cats. Link to comment Share on other sites More sharing options...
mwiener2 Posted January 22, 2013 Share Posted January 22, 2013 An emissions test should not make more than 3-5psi boost.... if that. If you can hear your blow off valve, demand a retest possibly with a different driver. They are doing it wrong. My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
