chucktoo Posted July 26, 2005 Share Posted July 26, 2005 Found two sources of hub adapters: http://www.forperformance.com/wtspacer.html Can get 5x100mm to 5x114.3mm that are 15 mm thick for $110 per pair - ask for Mike Has thicker adapters 1" ans 1.25" thick http://www.ezaccessory.com/.sc/ms/dd/1105739468397354/9/nc/Wheel%20Adapters--5%20Lug%20%28Pattern%20Conversion%29/123/Wheel%20Adapter%205%20Lug%20100%20To%205%20Lug%204%2E5%26quot%3B Now there is a large chhoice of wheels available - how large do you want to go ? Link to comment Share on other sites More sharing options...
inthedeck Posted July 26, 2005 Share Posted July 26, 2005 I was just pondering this situation. Why would subaru (or other manufacturers) do this? What's the difference (beyond size, obviously) that the 5x100 and 5x114.3 bolt pattern makes, in relation to the car? Is it because of stress on the driveline? or something else? Link to comment Share on other sites More sharing options...
chucktoo Posted July 26, 2005 Author Share Posted July 26, 2005 5x100 is a nice metric number 5x114.3 is really 5x 4.5" a nice english number. I think it is just that simple - Metric vs English Link to comment Share on other sites More sharing options...
Xenonk Posted July 26, 2005 Share Posted July 26, 2005 it's a torque issue. Keefe Keefe Link to comment Share on other sites More sharing options...
inthedeck Posted July 26, 2005 Share Posted July 26, 2005 it's a torque issue. Keefe And as a result, a car like the STi can produce more torque? So, would adding one of these adapters change the characteristics of the 'torque' band in the LGT? I am sure that since you would be able to add wider wheels/tires that the 5x114.3 would produce a slight effect? Would it be detrimental, in any way? TIA for the responses! Link to comment Share on other sites More sharing options...
chucktoo Posted July 26, 2005 Author Share Posted July 26, 2005 Torque is Torque - ft - lb - force at a radius For 114.3m diameter the shear force on the bolts is 14% less than 100 mm = a little stronger. 114.3 mm gives you a much larger selection of wheels. Link to comment Share on other sites More sharing options...
PhilT Posted July 26, 2005 Share Posted July 26, 2005 Torque is Torque - ft - lb - force at a radius For 114.3m diameter the shear force on the bolts is 14% less than 100 mm = a little stronger. 114.3 mm gives you a much larger selection of wheels. I believe that in a flanged coupling, as a wheel essentially is, the torque is transmitted through the mating faces not through the bolts. The bolts are just there to keep the driving faces together, there should be no shear forces on the bolts at all. It could be a metric / imperial thing, or it could be a strength issue with the wheels / hub. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
Xenonk Posted July 26, 2005 Share Posted July 26, 2005 if that was the case, then why bother torquing down the lugs at 80 lbs vs some of the 5x120 bolt pattern typical torque specs at 100 lbs? There are lateral forces at play as well. Ever seen a bolt sheer off? In all, the bolts are there for a reason as well as spacing. This goes back to having a center lug bolt vs. 5 bolt pattern.. when you really look at it, why do some cars are 4, 5 and 6 lugs? Keefe Keefe Link to comment Share on other sites More sharing options...
dv8ingvector Posted July 26, 2005 Share Posted July 26, 2005 if that was the case, then why bother torquing down the lugs at 80 lbs vs some of the 5x120 bolt pattern typical torque specs at 100 lbs? There are lateral forces at play as well. Ever seen a bolt sheer off? In all, the bolts are there for a reason as well as spacing. This goes back to having a center lug bolt vs. 5 bolt pattern.. when you really look at it, why do some cars are 4, 5 and 6 lugs? Keefe That could also have something to due with the pitch of the thread and or composition of the studs..just thinking out loud. Link to comment Share on other sites More sharing options...
inthedeck Posted July 26, 2005 Share Posted July 26, 2005 Torque is Torque - ft - lb - force at a radius For 114.3m diameter the shear force on the bolts is 14% less than 100 mm = a little stronger. 114.3 mm gives you a much larger selection of wheels. So, by this you mean that the 114.3 mm gives you greater strength? or is it the 100mm that gives it greater strength? I would assume it's the 114.3 mm that's stronger... Now, suppose you do add something like this to the LGT, what types of effect would it have on the car? the drivetrain, the diffs? etc. I know the STi incorporates the bigger pattern...but again, stock it's putting out a bit more power than the LGT. So what's the reasoning that the LGT only gets the 5x100 spacing? And yes, I can see how you would have MANY more options for rims, with this piece...but then wouldn't you have to worry about clearance/offset, or does that type of issue just remain as is, with closest to stock offset being the most preferential? Link to comment Share on other sites More sharing options...
PhilT Posted July 26, 2005 Share Posted July 26, 2005 if that was the case, then why bother torquing down the lugs at 80 lbs vs some of the 5x120 bolt pattern typical torque specs at 100 lbs? There are lateral forces at play as well. Ever seen a bolt sheer off? In all, the bolts are there for a reason as well as spacing. This goes back to having a center lug bolt vs. 5 bolt pattern.. when you really look at it, why do some cars are 4, 5 and 6 lugs? Keefe I agree on that, large cornering forces could break off a poorly tightened or weakened stud, but then the bolt is under tensile stress not shear stress. I still believe that if the nuts are tightened correctly, there should be no shear stresses in the studs. If there were, the designers would have used fitted bolts not clearance bolts. The more torque you want to put through a wheel, the greater the clamping force you need, thats why more powerful cars have 6 bolts, and civics have 4 bolts. Double Award Winning Legacy GT Wagon Link to comment Share on other sites More sharing options...
SC GT Posted July 26, 2005 Share Posted July 26, 2005 If the adapters are 15 mm thick, doesn't that mean you will have to find a +60 mm offset rim in order to have the equivalent of a + 45 mm offset? If so, I think your list of available 5X114.3 rims just shrunk quite a bit. Link to comment Share on other sites More sharing options...
red beast Posted July 26, 2005 Share Posted July 26, 2005 they look like h an r quailty. http://www.hrsprings.com/site/index.html Link to comment Share on other sites More sharing options...
Xenonk Posted July 26, 2005 Share Posted July 26, 2005 If the adapters are 15 mm thick, doesn't that mean you will have to find a +60 mm offset rim in order to have the equivalent of a + 45 mm offset? If so, I think your list of available 5X114.3 rims just shrunk quite a bit. That is correct! So for all of you thinking of getting these hub adapters, now you have to find even HIGHER offsets to make the rims work. Keefe Keefe Link to comment Share on other sites More sharing options...
chucktoo Posted July 27, 2005 Author Share Posted July 27, 2005 You might find this helpful understand tradeoffs; http://www.1010tires.com/WheelOffsetCalculator.asp Link to comment Share on other sites More sharing options...
driggity Posted August 2, 2005 Share Posted August 2, 2005 Don't the stuck lugs stick out more than 15mm from the hub? If so you'd probably have to trim them down or replace them with shorter lugs if you wanted to use the 15mm thick adaptor. Link to comment Share on other sites More sharing options...
slip304 Posted August 2, 2005 Share Posted August 2, 2005 sounds like alot more trouble than simply finding 5-100 bolt wheels.. Now what I would like to know is if you are saying that the sti requires additional lug strenth due to added stress from power/torque, what happens when we increase power/ torque in the legacy? I cant honestly see that being an issue.. I guess you learn something new everyday.. Link to comment Share on other sites More sharing options...
chucktoo Posted August 2, 2005 Author Share Posted August 2, 2005 I have been lookimg for 18x10s in 5x100 with a 10 mm offset. If you know where to find them please let me know. I would just as soon not use the adapters. I can find them in 5x114.3 with a 25 mm offset so a 15 mm adapater works just fine. Link to comment Share on other sites More sharing options...
