m_dogg Posted November 7, 2012 Share Posted November 7, 2012 So i picked up a 20mm rear sway bar (bushings included) for my 2.5i. My question is, do I need bigger brackets or can I get away with stockers? Not sure what's the dia on a stock bar... Thanks! Link to comment Share on other sites More sharing options...
sactojesse Posted November 7, 2012 Share Posted November 7, 2012 Get the AVO rear sway bar reinforcement brackets. I'm running the AVO RSB reinforcement brackets with a JDM 20 mm hollow RSB. (USDM RSB is 16 mm solid on Legacies and 15 mm solid on Outbacks.) The stock RSB mounts are really wimpy and you don't want to break one. Link to comment Share on other sites More sharing options...
m_dogg Posted November 7, 2012 Author Share Posted November 7, 2012 ^Thanks for the tip friend, that was one of the items I picked up with the bar and end links of course Looks like I'll need to pick up a 20mm bushing brackets in this case... Link to comment Share on other sites More sharing options...
soloz2 Posted June 25, 2013 Share Posted June 25, 2013 I've been running the 20mm jdm bar for a couple years without the braces. Sent from my SAMSUNG-SGH-I747 using Tapatalk 2 Current: 16 Crosstrek Premium w/ Eyesight & 05 Outback XT 5MT Past Subies: 14 FXT Premium, 14 WRX hatch, 06 Legacy 2.5i SE 5MT, 98 Outback wagon Link to comment Share on other sites More sharing options...
ragman Posted June 25, 2013 Share Posted June 25, 2013 No need to replace the bushing brackets. They give you new bushings that fit the stock brackets just fine. Link to comment Share on other sites More sharing options...
