beebs Posted October 24, 2012 Author Share Posted October 24, 2012 The fuse box is located to the right side of the pedal assembly. Get down there and look. The cover pops right off. It is labeled and tells you what each fuse is. If the fuse is burnt out it is fairly obvious as the U shaped filament will be burned out. BTW, I hope you are serious are are not another incarnation of brok's trolling personas. alright i'll go check it out real quick. And i dont even know who brok is, i wouldnt waste my time on here trolling. I've got better things to do Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 24, 2012 Share Posted October 24, 2012 Oops, I meant to the left side of the pedal assembly, lol. I should go to sleep. Link to comment Share on other sites More sharing options...
beebs Posted October 24, 2012 Author Share Posted October 24, 2012 The other thing you can do is start pulling fuses when you find one that turns off the lights that's the circuit to focus on when i unplugged it, the light was off. so it most likely is the switch right? Link to comment Share on other sites More sharing options...
09obpleg Posted October 24, 2012 Share Posted October 24, 2012 Unplugged what the fuse or the switch if it's the switch you unplugged then more then likely is the switch and its either misadjusted or the switch is bad If its the fuse you pulled it still could be the switch or a writing issue Link to comment Share on other sites More sharing options...
beebs Posted October 24, 2012 Author Share Posted October 24, 2012 Unplugged what the fuse or the switch if it's the switch you unplugged then more then likely is the switch and its either misadjusted or the switch is bad If its the fuse you pulled it still could be the switch or a writing issue Well i just unplugged ever fuse, the u shapes are all good. Light Never turned off. Which fuse if for the red lights in the back? I think i might have to adjust it, i have the haynes manual, should i follow that? Link to comment Share on other sites More sharing options...
beebs Posted October 24, 2012 Author Share Posted October 24, 2012 The adjusting part is very complicating, i really dont understand. But if i leave the switch unplugged, my battery doesnt have to be disconnected right? Link to comment Share on other sites More sharing options...
beebs Posted October 25, 2012 Author Share Posted October 25, 2012 Unplugged what the fuse or the switch if it's the switch you unplugged then more then likely is the switch and its either misadjusted or the switch is bad If its the fuse you pulled it still could be the switch or a writing issue my cousin helped me fix it, it wasnt adjusted right thank you for your help! Link to comment Share on other sites More sharing options...
monkeyposeur Posted October 26, 2012 Share Posted October 26, 2012 Glad you got it worked out. Link to comment Share on other sites More sharing options...
