O.C.D. Posted October 21, 2012 Share Posted October 21, 2012 Hello all. I am a long term lurker as I have Been in the Subaru world for 18 years or so. Owned many of them and now I am after a LGT Wagon. On NASIOC, 3G Impreza and USMB. I found a 2005 with 114,000 miles, manual, new turbo and timing, really good shape, etc. http://www.monumentmotors.com/2005-subaru-legacy-2-5gt-wagon/ As I am not new to these cars I know the mileage is not too bad. I drove it and she tracks strait, has pretty good power and brakes well. I already talked him down to $11,700 and free tires. So what I am afraid of is? I know of the ringland issue on these older 2.5's. There is no history as it was a broker trade. It was a one owner car. No knowledge of clutch or tranny maintenance. Is it true that this is a limited as it was a manual wagon from this year? What would you all say about this car? Thanks in advance. Jon Link to comment Share on other sites More sharing options...
O.C.D. Posted October 21, 2012 Author Share Posted October 21, 2012 Forgot to add that it has new timing belts and pulleys as well. STI pedal covers are on there as well? That would lead me to believe young owner and she could have been abused or the owner liked pedal covers? Dealer stated that the Legacys have an oil filter to the turbo which clogs and starves the turbo. That is why it died? Is this true? Dealer said the WRX's don't have this and he removed it when the new turbo went in. Guy sells mainly used Subarus and seems to know his stuff. Link to comment Share on other sites More sharing options...
Matt166 Posted October 21, 2012 Share Posted October 21, 2012 Hi, I have the exact same car in silver. Worried about ringland? Get a compression test, also understand that while there are a few documented cases of ringland failure, there are many, many higher mileage 05 Gt's out there without it. Sometimes I feel like coming onto the forum makes me paraniod about my car because the majority of people join when they get problems and are seeking advice. The new turbo is a big plus, but you have to be absolutely certain that parts of that old blown turbo are not still in the engine - who did the install? what else did they do to support the install and make sure the oil isn't contaminated? He is right about the filters, they are called banjo bolts FYI. The jury is out if you should keep them in or not - I think more important is to keep your OCI's at 3000 miles and lower and use good synthetic oil (not mobil 1). It would have been nice to see some service records for the car. My banjo filters are out FWIW. The STI pedals I wouldn't worry about. From what the guy is saying, it seems like he knows what he is talking about. Press the clutch in on idle, my throw out bearing whistles on occasion, will need replacing soon. Good luck, Its been love hate for me (mostly love), but I would much rather put money into this car than my old RSX! I feel like it does everything. Link to comment Share on other sites More sharing options...
Matt166 Posted October 21, 2012 Share Posted October 21, 2012 Oh, and the manual comes in LTD and non LTD. They only made the wagons in 05 and I think a few in 06. Link to comment Share on other sites More sharing options...
O.C.D. Posted October 21, 2012 Author Share Posted October 21, 2012 Banjo bolts are what attach to a fluid line and have a passage to bolt down to a caliper or turbo. They are not filter? Maybe I am confused. Is there one that has a filter there? My 2011 wrx didn't have that. My other 2 Subaru's were n/a so I may have never seen this. Thank you for the insights. Mechanics is a Subaru tech here and he used OEM parts. The engine cowl was on but that turbo is brand spankin new. I can't confirm it is a Subaru turbo at the moment. Should be a vf40? He gave me the mechanics number as well for my restoration needs. Guy seems really legit and knowledgeable about Subies. I will ask about the oil change after turbo service. But as stated, is this worth the money? Link to comment Share on other sites More sharing options...
O.C.D. Posted October 21, 2012 Author Share Posted October 21, 2012 Ok I am learning here. Banjo bolt filter removal. Interesting to know now. http://legacygt.com/forums/showthread.php/2-5gt-turbo-oil-supply-banjo-bolt-filter-removal-62371.html Link to comment Share on other sites More sharing options...
Matt166 Posted October 21, 2012 Share Posted October 21, 2012 Ok I am learning here. Banjo bolt filter removal. Interesting to know now. http://legacygt.com/forums/showthread.php/2-5gt-turbo-oil-supply-banjo-bolt-filter-removal-62371.html Sorry, must have missed that one. Well, I guess it depends. If it were me, and everything I mentioned checked out ok, then I would probably pay $11-12k on the basis I had some sort of warranty. My particular concern would be pieces of that toast turbo floating around in your engine, and that turbo blew for a reason, I would want to know what that was. My car had a blown turbo 10k before I purchased it, the cause was clogged banjo filter (I suspect longer OCI intervals than 3k), it also caused burnout on a valve in cyl4. The owner replaced the turbo with a used unit, and had the engine rebuilt. I could deal with the used turbo - I had BNR rebuild it as soon as I bought it for $375, I just wanted to make sure nothing was still in that engine. I guess the question is how much do you really want the car. I fell in love with mine as soon as I saw it, and because of that I missed a bunch of stuff that I probably should have paid more attention to while viewing it. Whatever happens, good luck. FYI I paid a couple of hundred over KBB value, but I recognize these cars are rare, and I really wanted one. Link to comment Share on other sites More sharing options...
Matt166 Posted October 22, 2012 Share Posted October 22, 2012 Hold the phone, just found this browsing. http://denver.craigslist.org/cto/3351404593.html Go take a look before you buy your original. Good luck - wish I was closer to look myself! Link to comment Share on other sites More sharing options...
bigjweb Posted October 22, 2012 Share Posted October 22, 2012 I'm considering selling my wagon. 69K 5spd silver color. HTA 68, Pw intercooler, custom tune for e85 with accessport, new tires. Pretty clean. Located in Denver Link to comment Share on other sites More sharing options...
O.C.D. Posted October 22, 2012 Author Share Posted October 22, 2012 Hold the phone, just found this browsing. http://denver.craigslist.org/cto/3351404593.html Go take a look before you buy your original. Good luck - wish I was closer to look myself! He he he, saw that as well and have reached out. We shall see. I am a patient person but I know these 5-speeds are rare. Hopefully will figure it out. I really think the dealer car is a good one. I am not too worried about the turbo being blown. But I could be wrong. Link to comment Share on other sites More sharing options...
O.C.D. Posted October 22, 2012 Author Share Posted October 22, 2012 I'm considering selling my wagon. 69K 5spd silver color. HTA 68, Pw intercooler, custom tune for e85 with accessport, new tires. Pretty clean. Located in Denver Thank you but I am looking for a stock LGT. Link to comment Share on other sites More sharing options...
O.C.D. Posted October 22, 2012 Author Share Posted October 22, 2012 Well I did a ton more research at work today and am really focusing on the Denver car with 44,000 fewer miles. But that means a private car loan so I applied. Waiting to hear on it. Called the owner and he says it is a great car in great shape. So now I just wait.... And I hate waiting. Lol Link to comment Share on other sites More sharing options...
ttnio Posted October 22, 2012 Share Posted October 22, 2012 They found their wagon of choice. No worry's.The used market is red hot for wagon's & Spec B's. The factor is availability. People are waiting & watching. Shopping for a car of your choice is always fun... I'm considering selling my wagon. 69K 5spd silver color. HTA 68, Pw intercooler, custom tune for e85 with accessport, new tires. Pretty clean. Located in Denver Link to comment Share on other sites More sharing options...
O.C.D. Posted October 23, 2012 Author Share Posted October 23, 2012 Well I got the pre-approval for the nicer Wagon and am pursuing the sale as we speak. Hopefully I will be a real member here soon. Wish me luck. Link to comment Share on other sites More sharing options...
O.C.D. Posted October 23, 2012 Author Share Posted October 23, 2012 And 20 minutes later I have a new Legacy, lol. Got her for $11,500 @ 4.49% Heck of a good rate! Just in case it is this car here: http://denver.craigslist.org/cto/3351404593.html Subaru number 4 here I come. Link to comment Share on other sites More sharing options...
Dujo Posted October 23, 2012 Share Posted October 23, 2012 Have fun. Time for a new up and down. Enjoy! Link to comment Share on other sites More sharing options...
bigjweb Posted October 24, 2012 Share Posted October 24, 2012 Is that a limited? Link to comment Share on other sites More sharing options...
ttnio Posted October 24, 2012 Share Posted October 24, 2012 Almost, but not quite, Limited's are sunroof, and leather bottoms,& etc. Is that a limited? Link to comment Share on other sites More sharing options...
O.C.D. Posted October 24, 2012 Author Share Posted October 24, 2012 Have fun. Time for a new up and down. Enjoy! Cornfused on that statement? Link to comment Share on other sites More sharing options...
O.C.D. Posted October 24, 2012 Author Share Posted October 24, 2012 Almost, but not quite, Limited's are sunroof, and leather bottoms,& etc. Premium like my last WRX. No leather but heated seats, manual and whatnot. Exactly what I wanted. Link to comment Share on other sites More sharing options...
Turkeylord Posted October 24, 2012 Share Posted October 24, 2012 Congrats! Link to comment Share on other sites More sharing options...
O.C.D. Posted October 24, 2012 Author Share Posted October 24, 2012 And the car is apparently getting serviced right now. New rotors, pads, flush and bled. Cost to me is $200. New brakes, why not?! I can't wait to pick her up Saturday. Link to comment Share on other sites More sharing options...
RuskiTrombone Posted October 24, 2012 Share Posted October 24, 2012 Congrats and welcome to the boards. Link to comment Share on other sites More sharing options...
RuskiTrombone Posted October 24, 2012 Share Posted October 24, 2012 Get the decal: http://www.fastwrx.com/wamade.html Link to comment Share on other sites More sharing options...
BMA44 Posted October 24, 2012 Share Posted October 24, 2012 Cornfused on that statement? up and down pipe. stage 2! Link to comment Share on other sites More sharing options...
