Stang70Fastback Posted October 27, 2012 Share Posted October 27, 2012 http://www.globalenergydevices.com/ I stopped reading here: It’s well known that an Internal combustive engine only has about a 40% efficient fuel burn and 50-70% of the fuel (gas or diesel) that you purchase is un-burned during the combustion process. Diesel engines normally expel this un-burned fuel directly out of the exhaust pipe. On gasoline engines this un-burned fuel goes into the catalytic converter, where it is re-burned and wasted. To make matters even worse, the constant build up of this un-burned fuel (inside the catalytic converter) restricts the flow of exhaust, which ultimately wastes even more fuel. Link to comment Share on other sites More sharing options...
