funnyman06 Posted December 22, 2012 Share Posted December 22, 2012 Does the Clean Sweep have its own volume control or can you still control volume off the stock head unit? Also if he was looking to just replace the front speakers, how much power does the stock headunit actually put out? Link to comment Share on other sites More sharing options...
Wang Lung Posted December 22, 2012 Share Posted December 22, 2012 It has its own volume control. The head unit pot still functions. But you program the CS at a given volume setting, mine was programmed at 35 on the dial. So if you deviate the head unit volume from your setpoint, you've misaligned your CS. Having said that, most people wouldn't even notice. Mrs. Lung thinks gadgets like this are silly and just uses the HU volume. Link to comment Share on other sites More sharing options...
funnyman06 Posted December 27, 2012 Share Posted December 27, 2012 Any info on stock head unit rms or max watts per channel? Link to comment Share on other sites More sharing options...
mwiener2 Posted December 28, 2012 Share Posted December 28, 2012 less than any decent speakers max requirments My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
09blkL3g Posted December 28, 2012 Share Posted December 28, 2012 Look into audio control...they have units just like the CS.. you dont need to connect every channel on the clean sweep as labeled, you can always use a y splitter and split the front stage towards whatever kind of setup you need. Any decent eq w/ a built in line driver will work as the same too..yes you will not get all the tuning functions, but believe me its not needed. Link to comment Share on other sites More sharing options...
FunkyMonkey Posted January 10, 2014 Share Posted January 10, 2014 I want to get one to put in my amp and sub. If I do this, I can put music through the aux ?? This is mind blowing. Can this be explained to me Link to comment Share on other sites More sharing options...
