gregrock1989 Posted October 2, 2012 Share Posted October 2, 2012 i drive a 2003 l se wagon. im looking for an alternative to standard steel rims for the winter. so far these vw rims caught my eye, how can I be sure if they will fit and wont damage the drivetrain? the tire size is the same as what i have on now 205/55R16. http://i.ebayimg.com/00/s/NjY2WDEwMDA=/$T2eC16FHJGkE9no8fzMpBQ,oe85LNw~~48_20.JPG http://i.ebayimg.com/00/s/NjY2WDEwMDA=/$T2eC16FHJGkE9no8fzMpBQ,oeQpInQ~~48_20.JPG Link to comment Share on other sites More sharing options...
zambazil Posted October 2, 2012 Share Posted October 2, 2012 Even if it fits, I wouldn't. Too much identified with VW. 0.02¢ Link to comment Share on other sites More sharing options...
StoplightAssassin Posted October 3, 2012 Share Posted October 3, 2012 I'd rather use the wheels the OP posted as snows than a set of steelies. Then he'd really look like a VW or Honda. OP you need to find out what the bolt pattern is for those wheels. Some Jettas have a 5x100 lug pattern, but they usually have low offsets. In the long term it may cause some premature wear on your wheel bearings, especially if they haven't been replaced yet. Link to comment Share on other sites More sharing options...
Drift Motion Posted October 3, 2012 Share Posted October 3, 2012 I'd rather use the wheels the OP posted as snows than a set of steelies. Then he'd really look like a VW or Honda. OP you need to find out what the bolt pattern is for those wheels. Some Jettas have a 5x100 lug pattern, but they usually have low offsets. In the long term it may cause some premature wear on your wheel bearings, especially if they haven't been replaced yet. it says on the wheels 16x6.5 +50 so offset is not an issue center bore might be... Link to comment Share on other sites More sharing options...
StoplightAssassin Posted October 3, 2012 Share Posted October 3, 2012 it says on the wheels 16x6.5 +50 This is the lug pattern? Sounds like wheel dimensions to me. Link to comment Share on other sites More sharing options...
gregrock1989 Posted October 3, 2012 Author Share Posted October 3, 2012 So do you guys know what the bolt pattern and offset for my car is by chance? I'm also checking scrap yards for identical legacy rims.. found 3 from a 2002 and 1 from a 1998, which leads me to another question. Would these year differences matter? Thanks. Link to comment Share on other sites More sharing options...
dmanaenk Posted October 3, 2012 Share Posted October 3, 2012 I'd take their BBS rims. Otherwise - no. 666 Link to comment Share on other sites More sharing options...
DeleriousZ Posted October 4, 2012 Share Posted October 4, 2012 Be wary when using VW wheels. Most of them use lug bolts that have a ball seat, rather than our cone (taper) seat lug nuts. Running cone lugs on ball seats is super unsafe. Link to comment Share on other sites More sharing options...
dmanaenk Posted October 4, 2012 Share Posted October 4, 2012 Be wary when using VW wheels. Most of them use lug bolts that have a ball seat, rather than our cone (taper) seat lug nuts. Running cone lugs on ball seats is super unsafe. Yeah, important point. Especially given that VW center bore is 1mm larger, so wheels won't be hubcentric either. I think VW uses 13mm ball seat, so one would have to procure proper lug nuts. 666 Link to comment Share on other sites More sharing options...
