minitech Posted March 14, 2013 Share Posted March 14, 2013 I doubt its the sensor, or it would most likely be doing it all the time as sonn as you start driving. I still say that probably a faulty magnet ring in the hub is you issue. (nothing against Moog i know people have had good success with them) However, if you do get an abs sensor don't get it from Advance Auto they are ripping people off right now (which is odd because they are usually the cheapest), i would purchase one through rock auto or maybe Amazon prime. Cost about $50 bucks for a rear. But again it looks more like the hub is your problem to me. I would try another hub ( possible a TIMKEN ) and see if you problem is still there. If it still is then you should get an ABS sensor. Sorry to here that man i know it sucks but they are making very crappy parts these days usually some how from China re-boxed. Link to comment Share on other sites More sharing options...
mattg Posted March 14, 2013 Share Posted March 14, 2013 Check my thread on ABS/tone ring issues. Mine ended up being a dinged tone ring and I had to have that hub replaced. Link to comment Share on other sites More sharing options...
08SpecB_DE Posted March 17, 2013 Share Posted March 17, 2013 I figured it would be the hub since I never had the problem until I installed it. I've noticed it seems to come on when going at a steady speed of 40-50. I need rear brakes, so I might as well get the OEM bearing and call it a day. Link to comment Share on other sites More sharing options...
NickB34 Posted March 18, 2013 Share Posted March 18, 2013 Correction just bought a Timken, using Amazon prime cost was a very cheap $81 shipped! They are supposed to be close to OEM quality, reading other post on LGT (here) they seem very sound and good quality too. i will report back on the CC function. Also i read that SKF is supposed to be a very good bearing maker and is an OEM manufacture for Subaru's bearings. They are also painted black on the end of the hub just like the Subaru ones are. So, those are two other options if you cant get a OEM one from Subaru. I did this same thing a few weeks ago. Hard to argue the price and having it shipped to the door. No issues since I installed it. Link to comment Share on other sites More sharing options...
