ScoobieLGT Posted September 23, 2012 Share Posted September 23, 2012 I know this question has been asked before but some people say different things... How can I disable my DRLs on my 07 LGT? One of my headlights went out and I want to get a set of PnP HIDs but need to disable the DRLs first. Any help? Thanks! Link to comment Share on other sites More sharing options...
AkumaMax Posted September 24, 2012 Share Posted September 24, 2012 If you search for DRL disable you will find it no problem. There is a unit under the dash just to the left of the Clutch pedal or Brake pedal there are 2 large connectors going into the unit 1 is black and 1 is white. The white one just unplug. Done! Link to comment Share on other sites More sharing options...
trickniner Posted September 24, 2012 Share Posted September 24, 2012 It's actually a little different for 2007. I just did this on my '07 last week. There is still a control module under than dash and you need to pull the connector out. But the wire you want is actually blue w/ black stripe (I think). Either way searching will get you to the right one. There is a link to an '07 specific picture from the main DRL discussion at somepoint. Good luck. It should only take you 10 minutes but I spent about 15 extra fighting with the wire i needed to pull. Link to comment Share on other sites More sharing options...
Mega Users paintpollz Posted September 24, 2012 Mega Users Share Posted September 24, 2012 I just never turn my lights off. problem solved. "Remember Danny - Two wrongs don't make a right but three rights make a left." Link to comment Share on other sites More sharing options...
ScoobieLGT Posted September 26, 2012 Author Share Posted September 26, 2012 It's actually a little different for 2007. I just did this on my '07 last week. There is still a control module under than dash and you need to pull the connector out. But the wire you want is actually blue w/ black stripe (I think). Either way searching will get you to the right one. There is a link to an '07 specific picture from the main DRL discussion at somepoint. Good luck. It should only take you 10 minutes but I spent about 15 extra fighting with the wire i needed to pull. I guess I should read a little deeper into certain threads. Haha Link to comment Share on other sites More sharing options...
Dbl_D718 Posted September 27, 2012 Share Posted September 27, 2012 You need to leave both harnesses plugged in under the dash, but there is one wire that needs cut or removed from the white harness. I forget which color. You can just unplug the white harness and it will disable your DRLs, but your high beams will no longer work. Just FYI. MODS: PW TMIC, Cobb catted DP, HKS cat-back, AVO filter, Bren e-tune; Konis/Epics, Advan RCII Link to comment Share on other sites More sharing options...
