monkeyposeur Posted November 21, 2012 Share Posted November 21, 2012 It could be the HLAs. Here is a video of my 22T after I replaced the HGs, seals, timing, etc. I didn't know what the sound was at first and I feared the worst. But it turned out to be a collapsed HLA on the driver's side, which was an easy fix. [ame=http://www.youtube.com/watch?v=VckpQAChYs0]Initial startup of 93 Subaru SS w/EJ22T after rebuild. - YouTube[/ame] Link to comment Share on other sites More sharing options...
trevorno Posted December 10, 2012 Author Share Posted December 10, 2012 How do I post a video? Can't seem to find any how to... Link to comment Share on other sites More sharing options...
BDII Posted December 10, 2012 Share Posted December 10, 2012 Upload it to youtube, then just paste the youtube link in here. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
trevorno Posted December 10, 2012 Author Share Posted December 10, 2012 Video here. Thanks BDII Link to comment Share on other sites More sharing options...
trevorno Posted December 10, 2012 Author Share Posted December 10, 2012 Also, I tried to start it this morning. Got a high pitched screeching noise but no cranking. I tried again a few minutes later and it started but ran like crap and died a few times. I started it again after a few more minutes and it runs like normal. I'm assuming the running like crap is probably old gas/dirty injectors, but I'm not sure about the high pitched starter noise. I've also been getting some persistent clicking noises when I turn the key on and for a few seconds after I turn the car off. I might just put a new starter in there for piece of mind, but I don't want to throw money away... Link to comment Share on other sites More sharing options...
BDII Posted December 10, 2012 Share Posted December 10, 2012 That does not sound good. Do a compression test. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
trevorno Posted December 11, 2012 Author Share Posted December 11, 2012 That does not sound good. Do a compression test. It goes away after about 5 minutes. Also, the engine temp gauge doesnt work but the heater works fine. I'm guessing coolant temp sensor. I'm getting it inspected by the state tomorrow, then an emissions test. We shall see. Link to comment Share on other sites More sharing options...
trevorno Posted December 12, 2012 Author Share Posted December 12, 2012 After driving it, the check engine light came on. Codes 35 and 51. Per the bbs, I'm going to replace the purge canister solenoid, then reset the ecu. I'm also going to replace the starter. Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 13, 2012 Share Posted December 13, 2012 I hope it helps. Old SSs are a can of worms. I'm speaking only from my own experience. Link to comment Share on other sites More sharing options...
trevorno Posted December 21, 2012 Author Share Posted December 21, 2012 Got it running. now I have a persistent tick while its running. I might do a compression test and change the oil after a few more miles and see what the results are. I'm hoping for HLA's and not rebuilding the engine. Link to comment Share on other sites More sharing options...
BDII Posted December 21, 2012 Share Posted December 21, 2012 If it's the motor do a 2.2L stroker kit Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 21, 2012 Share Posted December 21, 2012 That will only set you back $3k or so, lol. Link to comment Share on other sites More sharing options...
BDII Posted December 21, 2012 Share Posted December 21, 2012 He'll need a bigger turbo, bigger brakes, better tires, bigger intercooler, injectors, fuel pump, oil pump, headers, full exhaust, suspension and a stronger transmission too. So more like 15k Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 21, 2012 Share Posted December 21, 2012 Yeah, the $3k is just for the crank, pistons, and rods. The other stuff is just minor details. Also need dohc heads, wiring harness merge, ecu, and 4.5 quarts of quality oil. Link to comment Share on other sites More sharing options...
trevorno Posted December 22, 2012 Author Share Posted December 22, 2012 I'll try to get another video done with the noise. Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 22, 2012 Share Posted December 22, 2012 Hopefully it is just an HLA. Pretty easy to get at and replace. A new one is about $6-8. You could check the yards for older leggys and pull a bunch of them off for next to nothing too. How does the sound compare to the video I posted a few pages back? After almost a year my SS is running just about like it should. They can be frustrating. But I know a lot more about Subarus now, lol. Link to comment Share on other sites More sharing options...
trevorno Posted December 31, 2012 Author Share Posted December 31, 2012 Here is the video of the noise. Link to comment Share on other sites More sharing options...
monkeyposeur Posted December 31, 2012 Share Posted December 31, 2012 Sounds like a collapsed HLA to me. Link to comment Share on other sites More sharing options...
trevorno Posted January 9, 2013 Author Share Posted January 9, 2013 Mechanic confirmed it's an HLA. Big load off my mind. Link to comment Share on other sites More sharing options...
subikid90 Posted January 9, 2013 Share Posted January 9, 2013 If it's the motor do a 2.2L stroker kit I have a stroker kit for sale lol:) -Subikid90 1997 Legacy GT 5spd & EJ251 w/EJ25D heads ~10.5CR 1998 Legacy GT Limited waiting for EJ22T hybrid swap Link to comment Share on other sites More sharing options...
monkeyposeur Posted January 10, 2013 Share Posted January 10, 2013 Man, I wish I had some xtra money to take that off your hands subikid. Link to comment Share on other sites More sharing options...
