swagon2.5 Posted September 19, 2012 Share Posted September 19, 2012 So i had my 99 LGT up on my hoist at work the other day to check what i thought was a bad rear wheel bearing. As it turns out, it was not a wheel bearing, but both lateral links that the sway bar attaches to are bent, badly enough to be feathering my rear tires. so I''m going to be replacing the bars and doing a full alignment. I just want to make sure that lateral bars for an Impreza will fit the LGT? I'm thinking of getting these? I think they should work. http://www.ebay.ca/itm/Subaru-Imprez...ht_2321wt_1271 Link to comment Share on other sites More sharing options...
swagon2.5 Posted September 20, 2012 Author Share Posted September 20, 2012 Any help? Link to comment Share on other sites More sharing options...
Kennyfvholla Posted September 21, 2012 Share Posted September 21, 2012 Link is dead. Either way, not sure if those impreza links will fit. Don't even know what year they are from. Why do you not get OE Legacy lateral links. Btw, you should post up some pics of your links. Link to comment Share on other sites More sharing options...
swagon2.5 Posted September 21, 2012 Author Share Posted September 21, 2012 oh crap, i'll try the link again and i'll get pics of mine tomorrow Link to comment Share on other sites More sharing options...
swagon2.5 Posted September 21, 2012 Author Share Posted September 21, 2012 So I took a quick measurement at work this morning on an 06WRX and the lateral links are the same length as the ones on my 99LGT, gonna take a couple more but i believe the lateral links on both cars are the same. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted September 21, 2012 Share Posted September 21, 2012 Nice name BNR18g on 93oct Link to comment Share on other sites More sharing options...
swagon2.5 Posted September 21, 2012 Author Share Posted September 21, 2012 haha you too Link to comment Share on other sites More sharing options...
swagon2.5 Posted September 22, 2012 Author Share Posted September 22, 2012 So i measured the length of the links on both cars and its the same, the bushings are the same width and the sway bar mount is in the same spot. I'm going to buy the adjustable links and put them on, i'll post before and after pics when its done. Link to comment Share on other sites More sharing options...
SpecBamf41 Posted September 22, 2012 Share Posted September 22, 2012 Sweet thanks. Are you going with cheap ebay links? Just for you John. BNR18g on 93oct Link to comment Share on other sites More sharing options...
swagon2.5 Posted September 23, 2012 Author Share Posted September 23, 2012 The thought crossed my mind, but after looking a little more i found a set of Godspeed adjustable lateral links for about $40 more so i'll most likely go with those Link to comment Share on other sites More sharing options...
SpecBamf41 Posted September 25, 2012 Share Posted September 25, 2012 Are you getting the set with the adj trailing arm? And godspeed is not really any better. Their other products blow three goat balls sometimes. Cough fmic kit, turbo, cough. Problems with them I hear are the spearical bearings wearing out. Just for you John. BNR18g on 93oct Link to comment Share on other sites More sharing options...
swagon2.5 Posted September 26, 2012 Author Share Posted September 26, 2012 Ya I was going, but I guess not now, thanks for the heads up, I'll just call the dealer and price out some new ones, thanks again Sent from my BlackBerry 9780 using Tapatalk Link to comment Share on other sites More sharing options...
