GTTuner Posted September 15, 2012 Share Posted September 15, 2012 I had an idea. The clutch slave is a 13/16" bore piston. If I put a 1 inch bore slave in there it would lower the force needed for the master to push it. I found a couple of CNC universal slave cylinders online, on looks like it will almost bolt right up. Has anyone thought of doing this or have tried this? http://www.peterverdone.com/archive/files/hydraulic%20system%20theory.pdf Link to comment Share on other sites More sharing options...
iNVAR Posted September 16, 2012 Share Posted September 16, 2012 I was helping to move my friend's Audi RS4 which I'm sure has a clutch that holds as much as or more power than my ACT HD with WRX 06+ SMFW. His clutch felt very light and I almost put my foot through the floor. Then I got back in my car and my leg cramped up. Seriously though, immediately after that, I started thinking about why our clutch pedals are so heavy. Even when I had a stock clutch, I found that it was pretty heavy relative to everyone else's cars. BMW, Audi, Mini Cooper (same as BMW I guess), Nissan 240, etc. I'm sure everything's installed right too because I've been driving on it for 24K miles and engagement and everything is right. It's just heavy. Anyway, I thought about the clutch MC size... it's pretty small from what I recall. Link to comment Share on other sites More sharing options...
SubOperator Posted September 16, 2012 Share Posted September 16, 2012 Paul , what about the travel distance though ? larger diameter slave will require more fluid to travel same distance (to release the clutch). If the master is kept the same then the slave travel distance will be shorter, albeit the pedal will feel lighter. at least that's what I think. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 249K 2007 B9 Tribeca Limited DGM - 272K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
BAC5.2 Posted September 16, 2012 Share Posted September 16, 2012 Subaru clutches are heavy? [URL="http://legacygt.com/forums/showthread.php/proper-flip-key-interesti-159894.html"]Flip Key Development Thread[/URL] "Genius may have its limitations, but stupidity is not thus handicapped." - E. Hubbard Link to comment Share on other sites More sharing options...
iNVAR Posted September 16, 2012 Share Posted September 16, 2012 It's a bit heavy for me. A tiny bit lighter would be great. Bear in mind, I do a lot of clutchwork thanks to NYC. That hasn't been the experience with you? What are you comparing it to? I've only tried a few clutches recently and they were all significantly lighter than mine. Link to comment Share on other sites More sharing options...
iNVAR Posted September 16, 2012 Share Posted September 16, 2012 Paul , what about the travel distance though ? larger diameter slave will require more fluid to travel same distance (to release the clutch). If the master is kept the same then the slave travel distance will be shorter, albeit the pedal will feel lighter. at least that's what I think.you mean longer? that's my read on things too. Link to comment Share on other sites More sharing options...
Schrei Wolf Posted September 16, 2012 Share Posted September 16, 2012 You have it backwards, smaller MC = more travel but more force, larger MC = less travel but less force You could also get a bigger slave. Link to comment Share on other sites More sharing options...
iNVAR Posted September 16, 2012 Share Posted September 16, 2012 Oh wait, I misread what he said... yeah, so he had it right. I was thinking he meant the travel required, not actual travel of the piston. Which doesn't really make sense except in my screwed up head since travel require will remain constant. It's late, I'm just not thinking clearly. Link to comment Share on other sites More sharing options...
GTTuner Posted September 17, 2012 Author Share Posted September 17, 2012 I was thinking the same thing about piston travel. I am sure this billet slave mounting holes will not perfectly line up with the car. So I was thinking of making an adapter plate, (1/4 inch aluminum flat stock) to mount the slave on and to bolt to the trans. This way I could alter the distance if needed to get the correct travel. Once I get my clutch in I am going to purchase one and see if this will work. Link to comment Share on other sites More sharing options...
GTTuner Posted September 17, 2012 Author Share Posted September 17, 2012 You have it backwards, smaller MC = more travel but more force, larger MC = less travel but less force You could also get a bigger slave. Read the original post. I was refering to the slave, not the master. I found a good variety of 1 inch bore slave's but not any masters. Link to comment Share on other sites More sharing options...
GTTuner Posted September 18, 2012 Author Share Posted September 18, 2012 I installed the ACT HDSS yesterday, new WRX flywheel. Pedal effort is a non issue. My Spec had a heavier pedal. It's nice to have a clutch again. Link to comment Share on other sites More sharing options...
SubOperator Posted September 18, 2012 Share Posted September 18, 2012 Good to know Paul ! Ordering my parts today FWIW, I bled the slave cylinder and who knows why but the clutch feels better now. Not feather light but definitely better feel. 2005 LGT Wagon Limited 6 MT RBP Stage 2 - 249K 2007 B9 Tribeca Limited DGM - 272K SOLD - 2005 OB Limited 5 MT Silver - 245K SOLD - 2010 OB 6 MT Silver - 205K Link to comment Share on other sites More sharing options...
BDII Posted September 18, 2012 Share Posted September 18, 2012 Subaru clutches are heavy? if you have girly legs Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
Schrei Wolf Posted September 18, 2012 Share Posted September 18, 2012 Read the original post. I was refering to the slave, not the master. I found a good variety of 1 inch bore slave's but not any masters. I was responding to iNVAR Link to comment Share on other sites More sharing options...
Haight 05LGT Posted September 18, 2012 Share Posted September 18, 2012 Subaru clutches are heavy? Mine is a bit heavy. What is odd is that my former 2.5i had a fairly light clutch. My GT is a leg cramper in city traffic for sure. Link to comment Share on other sites More sharing options...
ssbtech Posted September 18, 2012 Share Posted September 18, 2012 Mine is quite heavy. When they replaced the clutch (OEM, warranty) it was quite light for the first little while then it firmed up again after a few months of use and has been that way for the last 7 years. Link to comment Share on other sites More sharing options...
Haight 05LGT Posted September 18, 2012 Share Posted September 18, 2012 I want a sure-fire way of lightening my clutch. Anyone with know-how up for writing a guide? Link to comment Share on other sites More sharing options...
ssbtech Posted September 18, 2012 Share Posted September 18, 2012 I don't know if we know why it's heavy to begin with. Why so much variation between stock clutches? Link to comment Share on other sites More sharing options...
Haight 05LGT Posted September 18, 2012 Share Posted September 18, 2012 I don't know if we know why it's heavy to begin with. Why so much variation between stock clutches? Not only is my clutch heavy but it is squeaky as well. I know the fix for that one and it is happening this weekend hopefully. Link to comment Share on other sites More sharing options...
ssbtech Posted September 18, 2012 Share Posted September 18, 2012 My clutch has been creaky for years. Link to comment Share on other sites More sharing options...
