scoobie2.0 Posted September 12, 2012 Share Posted September 12, 2012 It came to my attention that I really hated the look of the amber parking lights at night combined with my low beams. I thought about using the switchback leds from Diode Dynamics but didn't like how the white led's had a blue hue. After searching around I found an old thread indicating the wiring layout of the turn signal/parking light of the headlights. Huge thanks to SlightlyEvil and his old thread here: http://legacygt.com/forums/showthread.php/parking-light-wiring-question-94308.html?t=94308 All you'll have to do is simply cut the parking light power wire. There are 3 wires coming from the connector. 1 black (ground), and 2 solids w/ stripes. One of the 2 solid w/ stripe wires has a small dab of silver paint on it, this is the turn signal wire. Cut the wire that has NO dab of silver paint, that is the parking light wire. You'll have to do this on both headlights. Then just protect the cut/exposed wires with some electrical tape. Test the turn signals out to make sure you cut the right wires. Enjoy and admire your parking light free headlights at night! http://i613.photobucket.com/albums/tt211/lyledellota/2012-09-11185638.jpg [ame=http://www.youtube.com/watch?v=ds1uRIus5aI]Legacy GT Disabled Parking Lights - YouTube[/ame] Link to comment Share on other sites More sharing options...
Haight 05LGT Posted October 20, 2012 Share Posted October 20, 2012 Good Shit. Link to comment Share on other sites More sharing options...
Haight 05LGT Posted October 20, 2012 Share Posted October 20, 2012 Major problem with this...i just tried it, and now my tailights dont light up unless i step on the brake. You have the same problem? Link to comment Share on other sites More sharing options...
Haight 05LGT Posted October 20, 2012 Share Posted October 20, 2012 Bump. Can anyone shed light on this issue? I have yet to fix it as I cut the wire too close to the connector. Going to just buy a new wire and connector tomorrow and fix it then. Link to comment Share on other sites More sharing options...
jav2.5 Posted October 20, 2012 Share Posted October 20, 2012 I was gonna say just splice them, but forget that. Link to comment Share on other sites More sharing options...
scoobie2.0 Posted October 21, 2012 Author Share Posted October 21, 2012 Damn I thought I updated this. Guess it didn't save. Splice the orange wire back together. To achieve this mod without any complications, you will have to actually cut the parking light wire going to each turn signal bulb. There are 3 wires coming from the connector. 1 black (ground), and 2 solids w/ stripes. One of the 2 solid w/ stripe wires has a small dab of silver paint on it, this is the turn signal wire. Cut the wire that has NO dab of silver paint, that is the parking light wire. You'll have to do this on both headlights. Sorry for any confusion guys. Technically the tail light lights with headlights activated are considered "parking lights" which stupid me didn't think of. Cutting the orange wire disables all parking lights. This other method is proven to be 100% bug free by me after I had also noticed my tail lights and license plate lights not lighting up. Link to comment Share on other sites More sharing options...
scoobie2.0 Posted October 21, 2012 Author Share Posted October 21, 2012 Haight 05LGT, if you cut the wire too close to the connector, remove the connector and remove the old/short wire by releasing the the pin through the back. This will allow you to just strip and reconnect the longer section of the wire back into the connector. Hope this made sense. There are quite a few youtube videos on how to release the pin from the connector. Link to comment Share on other sites More sharing options...
Haight 05LGT Posted October 21, 2012 Share Posted October 21, 2012 Haight 05LGT, if you cut the wire too close to the connector, remove the connector and remove the old/short wire by releasing the the pin through the back. This will allow you to just strip and reconnect the longer section of the wire back into the connector. Hope this made sense. There are quite a few youtube videos on how to release the pin from the connector. Oh no worries there. I was able to fix it shortly after I did it. Link to comment Share on other sites More sharing options...
scoobie2.0 Posted October 21, 2012 Author Share Posted October 21, 2012 Okay cool. Ya sorry about that mix-up. The new edited version of the mod works 100% lol. If anyone needs, I can snap a pic of the wiring setup if my explanation is a bit confusing. Post 5 by SlightlyEvil in the thread I linked has a clearer explanation. I may also post up a new vid with my TRS retroquik system now in place. Link to comment Share on other sites More sharing options...
