LegacyDan Posted September 6, 2012 Share Posted September 6, 2012 So my Vredsteins are at the end of their life, they are 235/40/18 but the rub on the arch liner on full lock, so i was thinking of dropping down to 225/40/18. is this the best size for an 18x8 inch rim or am i better off sticking with 235's? Thanks Dan Link to comment Share on other sites More sharing options...
LosAngelesLGT Posted September 6, 2012 Share Posted September 6, 2012 245/45/18 for the win! =D http://legacygt.com/forums/showpost.php?p=3255882&postcount=149 EDIT: OPPS! That was in the middle of the night during a baby feeding. I am running 245/35/18 as whitetiger suggests. Link to comment Share on other sites More sharing options...
LegacyDan Posted September 6, 2012 Author Share Posted September 6, 2012 i think i would have even more rub issues if i went any bigger! Link to comment Share on other sites More sharing options...
whitetiger Posted September 6, 2012 Share Posted September 6, 2012 245/35/18 is closest to stock overall diameter. Link to comment Share on other sites More sharing options...
LegacyDan Posted September 6, 2012 Author Share Posted September 6, 2012 245/35/18 is closest to stock overall diameter. hmmm i wouldn't say there would be too much comfort in the 35 profile ones, roads a bad enough around here! there is some difference in price too between the 225/40 and the 245/35! $470 vs $800! Link to comment Share on other sites More sharing options...
whitetiger Posted September 6, 2012 Share Posted September 6, 2012 ^there is only a 5mm difference between those 2 sidewall heights of the sizes you listed. not so much difference in comfort. plus the 245 will protect the rim better than the 225 since the rubber sticks out past the rim more. price though, i agree with you. 245 wide choices are alot more $$$ Link to comment Share on other sites More sharing options...
LegacyDan Posted September 6, 2012 Author Share Posted September 6, 2012 i would go wider if i could but the rubbing issue is putting me off. i found a set of 225/40/18 locally pretty cheap, ill see if he has the 245/35 and if he thinks they will fit with no issues, i dont think they will though. Thanks for the advice Link to comment Share on other sites More sharing options...
whitetiger Posted September 6, 2012 Share Posted September 6, 2012 if your rim is +48, it will fit with just a very minor fender roll, if at all, and -1.5 camber all around. on stock suspension, my 245/40/17 fits with no issue on a 17x8 +48 rim. Link to comment Share on other sites More sharing options...
LegacyDan Posted September 6, 2012 Author Share Posted September 6, 2012 i think they are +48 alright but slightly lowered on jdm billies with sti pinks, i dont think they would rub on the arch just rub more on the wheel arch liner and wear a hole in that pretty quick! Link to comment Share on other sites More sharing options...
whitetiger Posted September 6, 2012 Share Posted September 6, 2012 they shouldnt rub on the liner unless the car is very low, lower than what pinks will do. you'll be fine. Link to comment Share on other sites More sharing options...
suds2250 Posted September 6, 2012 Share Posted September 6, 2012 I have 245/35/18's on rota +48 rims. Lowered with JDM bilsteins and prova springs, -1.0 camber. tires have never rubbed!!! 335HP/360Tq VF-22/1820 clone with Meth Link to comment Share on other sites More sharing options...
LegacyDan Posted September 6, 2012 Author Share Posted September 6, 2012 mine rubs on 235/40/18s though! Link to comment Share on other sites More sharing options...
whitetiger Posted September 6, 2012 Share Posted September 6, 2012 235/40/18 is a taller tire than 245/35/18 Link to comment Share on other sites More sharing options...
dingbang Posted September 7, 2012 Share Posted September 7, 2012 I run 245/35/18 on my gravels. Also lowered with koni/epics. No rubbing...but this is my last summer I will be getting out of these tires so they are a little worn down. Link to comment Share on other sites More sharing options...
LegacyDan Posted September 7, 2012 Author Share Posted September 7, 2012 no 245/35 available locally so i just went with a 225/40. fresh tires feel sooooo good! Link to comment Share on other sites More sharing options...
Stevedorez Posted September 7, 2012 Share Posted September 7, 2012 if your rim is +48, it will fit with just a very minor fender roll, if at all, and -1.5 camber all around. on stock suspension, my 245/40/17 fits with no issue on a 17x8 +48 rim. strange. On my Legacy BL Im using 8J +45 on stock blistein suspension with tires 225 40 18. No fender roll needed Link to comment Share on other sites More sharing options...
whitetiger Posted September 7, 2012 Share Posted September 7, 2012 thats because you are using 225 wide. put on a 245 wide tire and see. Link to comment Share on other sites More sharing options...
Stevedorez Posted September 7, 2012 Share Posted September 7, 2012 thats because you are using 225 wide. put on a 245 wide tire and see. D'oh... thanks for info Link to comment Share on other sites More sharing options...
lol slow Posted September 10, 2012 Share Posted September 10, 2012 225or even a 215. i have a 9.75" wide wheel on a 225 tire, yeah it'll probably come right off if I were to auto x the car or something, but otherwise it's fine and the ride wonderful. I'd do a 215 all day if i were you. Link to comment Share on other sites More sharing options...
