BrianHeston Posted August 29, 2012 Share Posted August 29, 2012 While looking under my dash to find the correct wiring location for the 4EAT Phase 2 Power Mode mod (http://sl-i.net/FORUM/viewtopic.php?p=280613&sid=54dfe8085c33d84681f31cd88f7bcebe#p280613) I found these two connectors that appear as though they should be connected, but aren't. I'm wondering if anybody here can identify them for me? The plugs are green, and each is only a single wire. On one plug it is a solid blue wire, and the other is a brown/black wire. They are located pretty much directly above the gas pedal. Thanks, Brian http://legacygt.com/forums/attachment.php?attachmentid=127188&stc=1&d=1346278295 Link to comment Share on other sites More sharing options...
Stasis Posted August 29, 2012 Share Posted August 29, 2012 Pretty sure it's for pulling codes from dash? Plug them together and codes will be displayed in a series of flashes on dash? :S Link to comment Share on other sites More sharing options...
monkeyposeur Posted August 29, 2012 Share Posted August 29, 2012 Stasis is right. Plug them in if you have a CEL and it will flash the code. Link to comment Share on other sites More sharing options...
johnegg Posted August 30, 2012 Share Posted August 30, 2012 but if you try and drive with them plugged in your car will run like crap and you will have 1/2 dozen trouble codes. leave them alone. buy a code reader if you want to read codes. Link to comment Share on other sites More sharing options...
monkeyposeur Posted August 30, 2012 Share Posted August 30, 2012 They come in handy on an OBDI like my '93 SS since that is the only way to read the codes. Link to comment Share on other sites More sharing options...
