S_S_H Posted August 29, 2012 Share Posted August 29, 2012 So I'm running 18x7.5 +45 rims with 225/40 tires. Lowered on BC's. setup ends up looking like this http://i.imgur.com/VDp1O.jpg I was wondering a couple of things: -What size spacer should I run to fill out the wheel gap nicely, for both front and rear? -What are some good brand spacers I could run? -Would I be ok with the same lugs nuts I'm using? Muteki Closed End Tuner Lugs (the ones in the link below) http://www.ebay.com/itm/160714801424#ht_6145wt_934 Link to comment Share on other sites More sharing options...
Drift Motion Posted August 29, 2012 Share Posted August 29, 2012 dont get spacers, get wheels that fit if you have to get a 15 mm bolt on spacer that are hub centric ($200 or so) you can re use the lug nuts Link to comment Share on other sites More sharing options...
mk6933 Posted August 31, 2012 Share Posted August 31, 2012 Well, you can get up to 5mm spacers with OEM hub. Link to comment Share on other sites More sharing options...
GTTuner Posted August 31, 2012 Share Posted August 31, 2012 Well, you can get up to 5mm spacers with OEM hub. Yes but there isn't enough of the center hub to stick out past the spacer and center the wheel. I tried a set, constant shimmy at high speeds, I don't recomend that. H&R makes 15mm hub centric. Link to comment Share on other sites More sharing options...
Drift Motion Posted August 31, 2012 Share Posted August 31, 2012 Yes but there isn't enough of the center hub to stick out past the spacer and center the wheel. I tried a set, constant shimmy at high speeds, I don't recomend that. H&R makes 15mm hub centric. the lug nuts should center the wheels make sure you wobble the wheels a bit as you tighten down the lug nuts I probably had about 10 sets of wheels now, or maybe more...never used hub centric ring, never had any issue I put the wheels on myself manually, no air tools Link to comment Share on other sites More sharing options...
