gas tank still leaking
well after replacing the one line here
http://briancloss.com/subigas.jpg
it was cracked in half by the middle plastic, its still leaking at the seam under it, i thought i had the problem fixed, guess not, should i get some gas tank putty ? or jb weld ? and success with any of these ?
thanks
yea ok sorry,
your looking at the tank from ontop, behind the rear seat, i cut away between the two acces ports, and i replaced the steel line, its leaking on part of the seam in the center at the back of the car,
and i was looking at dropping the tank but it seams like a big job, gotta drop the driveshaft and exhaust
well i got it all cleaned up and found exactly were its leaking, and slapped some seal all, gas and oil resitant, one guy said it held for 2 years, so well see, but i noticed its also leaking at the vent were it crossed through the frame il maybe replace it with some rubber hose around the frame
