BrianHeston Posted August 26, 2012 Share Posted August 26, 2012 I've searched but can't find an answer for this one. How can I clean the fogginess off of this side mirror? I can tell it's on the surface of the glass, because it is reflected in the mirrored sub-surface. I've tried a buffing wheel on my Dremel, Vinegar, Goo Gone, Windex... I just can't get this done and it's irritating! http://legacygt.com/forums/attachment.php?attachmentid=126869&d=1346000920 Link to comment Share on other sites More sharing options...
MasterPeon Posted August 27, 2012 Share Posted August 27, 2012 If it's hard water deposits, try vinegar? Maybe some tile cleaner? Link to comment Share on other sites More sharing options...
AkumaMax Posted August 27, 2012 Share Posted August 27, 2012 Looks as if the mirror is failing somehow. EDIT: I was just looking into some things and I have a simlar problem with my rear view mirror. Seems like it is the Silver Backing on the mirror that is fading. I never thought of this until I looked into it. IMO if the vinegar doesn't work then you have 2 choices. Reback the mirror with silver backing or get a new mirror. Link to comment Share on other sites More sharing options...
BrianHeston Posted August 29, 2012 Author Share Posted August 29, 2012 @MasterPeon: I'm not really sure what kind of deposit it is. I have tried vinegar and it did nothing. @AkumaMax: I don't believe it's the backing, because I can see the staining reflected IN the backing. Anyone else have any ideas? Link to comment Share on other sites More sharing options...
iNVAR Posted August 30, 2012 Share Posted August 30, 2012 you may have damaged the surface. on my 05 lgt, the surface doesn't feel like glass. it feels like plastic. you may have to use some sort of plastic polish (think like headlight restoration kits) to clear it up. Link to comment Share on other sites More sharing options...
Whatisit Posted August 31, 2012 Share Posted August 31, 2012 have you tried a rubbing compound? Link to comment Share on other sites More sharing options...
BrianHeston Posted August 31, 2012 Author Share Posted August 31, 2012 @iNVAR: I hadn't thought about it being a plastic. I guess I just assumed that it would be glass. I'll have to grab a headlight kit and see how that does. @Whatisit: I'm guessing the headlight kit would include rubbing compound. I haven't tried that yet, but it'll be my next step. I'll post back with the results. Thanks for the ideas guys! Link to comment Share on other sites More sharing options...
iNVAR Posted August 31, 2012 Share Posted August 31, 2012 might be different for your car, but i'm fairly certain mine's plastic. you can tell when you tap your knuckles against the surface. glass will feel more solid. Link to comment Share on other sites More sharing options...
Legacy noob Posted September 4, 2012 Share Posted September 4, 2012 Get the mothers headlight restoration wax and drill bit applicator, should come off, that stuff works great on glass stains Link to comment Share on other sites More sharing options...
PirateDuck Posted September 22, 2012 Share Posted September 22, 2012 If it bugs you, get a new mirror. The spots you're seeing are the reflective coating failing. The side view mirror is not glass with a reflective backing. It is plastic of some sort coated with a mirror finish. I went through the same situation and tried vinegar, headlight polishing and even polishing compound. All I got was a darker mirror because I was wearing away the mirror part. Keep you eye out for part outs. You can buy the mirror alone from Subaru for less than $80 if I recall correctly. Don't bother with the "mirror replacements" you'll see advertised as they are usually just stick-ons that will not work properly with the heated mirrors. Link to comment Share on other sites More sharing options...
