TrueWhiteBoy Posted August 11, 2012 Share Posted August 11, 2012 Me in my infinite wisdom decided that "well, stage 2 passed in Nevada, I'll just get an oil change and take it in California too" Passed all the tests but idle. 2005 Legacy GT Stage 2 (STI UP, 1 cat gutted DP, OTS CA Stage 2 Map) Anyone have any suggestions? Link to comment Share on other sites More sharing options...
Types4 Posted August 12, 2012 Share Posted August 12, 2012 Get a catted DP you are going to have to smog every couple years in CA. It's going to be cheaper in the long run. If you want to cheat, use water injection, I've seen it done before. There may also be certain additives you can put in your gas that may help, search google. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 12, 2012 Share Posted August 12, 2012 Yes you will need a Cat of some sort, but what exactly caused you to fail? CO, NOX, Hydrocarbons? that can help us. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
Drift Motion Posted August 12, 2012 Share Posted August 12, 2012 I passed with my Stage 2 + turbo with a cobb DP Link to comment Share on other sites More sharing options...
m sprank Posted August 12, 2012 Share Posted August 12, 2012 usually 1 cat will pass. but if the tune is running rich... what emissions did you fail on? was the car good and warm? how long had you driven it before testing? Link to comment Share on other sites More sharing options...
TrueWhiteBoy Posted August 13, 2012 Author Share Posted August 13, 2012 Using a OTS Cobb Stage 2 CA gas tune. I ran it hard for 15 minutes, but once I got there it had to sit for 20 minutes before they looked at it. I passed all visual inspections and functional inspections For idle: Idle | 838 RPM | 13.72 MEAS %CO2 | 0.4 MEAS %O2 | |100 MAX HC (PPM) | 17 AVE HC (PPM) | 226 MEAS HC (PPM) | |1.00 MAX CO(%) | 0.00 AVE CO(%) | 1.22 MEAS CO(%) | I hope this helps. Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 13, 2012 Share Posted August 13, 2012 yeah high CO and high HC you need a Cat of some sort. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
m sprank Posted August 13, 2012 Share Posted August 13, 2012 Need at least 1 working cat. Sounds like you might have none. Link to comment Share on other sites More sharing options...
TrueWhiteBoy Posted August 13, 2012 Author Share Posted August 13, 2012 Blah, I should in theory have 1 working one, unless it has gone bad somehow. I believe I have my old stock one, but it's in Vegas. Good reason for a trip I suppose. Link to comment Share on other sites More sharing options...
mwiener2 Posted August 13, 2012 Share Posted August 13, 2012 put 2 gal of E85 in My Mods List (Updated 8/22/17) 2005 Outback FMT Running on Electrons Link to comment Share on other sites More sharing options...
Chris GTO TT Posted August 13, 2012 Share Posted August 13, 2012 Blah, I should in theory have 1 working one, unless it has gone bad somehow. I believe I have my old stock one, but it's in Vegas. Good reason for a trip I suppose. Based on your mod list it looks like you have removed or gutted all the cats. Find an oem down pipe flash to stage 1 or stock and go get tested again. 2003 Baja 5MT 2016 Outback 2.5i Premium w/Eyesight Link to comment Share on other sites More sharing options...
UnBeGleavable Posted August 14, 2012 Share Posted August 14, 2012 I've got a all my stock stuff if you want to borrow it. Link to comment Share on other sites More sharing options...
TrueWhiteBoy Posted August 14, 2012 Author Share Posted August 14, 2012 I've got a stock pipe. It looks like I (kinda) lucked out, that my old roommate from Vegas is actually heading to Orange County this weekend and can bring my DP with him. The DP that's currently in there is supposed to have the first cat gutted, but the 2nd cat in place. Is it possible for the 2nd cat to go bad after time? The car has been stage 2 for nearly 60K miles now (it's at 120K now) Link to comment Share on other sites More sharing options...
m sprank Posted August 14, 2012 Share Posted August 14, 2012 Very possible second cat went bad (or disintegrated). Link to comment Share on other sites More sharing options...
TrueWhiteBoy Posted August 14, 2012 Author Share Posted August 14, 2012 Good to know. ...since it's the downpipe and heading out through the exhaust, I shouldn't worry about the disintegrating bits breaking anything, right? Man I wish I had a lift. I bet swapping it out would be so much easier. Link to comment Share on other sites More sharing options...
m sprank Posted August 15, 2012 Share Posted August 15, 2012 Should not "destroy" anything on the way out. But a large chunk, you never know. Link to comment Share on other sites More sharing options...
EPlascencia60 Posted August 16, 2012 Share Posted August 16, 2012 Sorry, late in the conversation but I'm a smog tech if any questions or concerns. P.S. join us at the Socal WRX F4 annual beach bbq this Saturday @ Bolsa Chica state beach 9am Link to comment Share on other sites More sharing options...
Drift Motion Posted August 16, 2012 Share Posted August 16, 2012 Sorry, late in the conversation but I'm a smog tech if any questions or concerns. P.S. join us at the Socal WRX F4 annual beach bbq this Saturday @ Bolsa Chica state beach 9am that's awesome! Link to comment Share on other sites More sharing options...
