Slickvic Posted July 18, 2005 Share Posted July 18, 2005 http://lieuxdits.free.fr/mazdalogo90.jpg Like knowing what the "candle" emblem on early 90's Mazdas stood for (I know now). Oh, you mean the "toiletbowl" logo? Link to comment Share on other sites More sharing options...
REM87O Posted July 18, 2005 Share Posted July 18, 2005 Sweet! LOL He keeps the distance for a while and then floors it...of course I floor it and get in his lane now...I see him hitting the steering wheel with his hand furiously ! Link to comment Share on other sites More sharing options...
DeepFreeze2 Posted July 18, 2005 Share Posted July 18, 2005 Specs for reference 2005 GS300 220hp 220tq 3.0l I6 2006 GS300 245hp 230tq 3.0l V6 2005 GS430 300hp 325tq 4.3 V6 2006 GS430 300hp 325tq 4.3 V6 So if it was a 430 it doesnt matter if it was an 05/06 but the 06 gs300 got a 25hp boost and went from a i6 to a v6 Uh....IIRC, the GS430 comes with a V8. YA RLY!!! Home of +2500 useless posts!!!! Link to comment Share on other sites More sharing options...
gfxdave99 Posted July 18, 2005 Author Share Posted July 18, 2005 Uh....IIRC, the GS430 comes with a V8. (puts down the crack pipe) yes V8 not v6.. hp/tq numbers are correct tho If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
SBT Posted July 18, 2005 Share Posted July 18, 2005 Uh....IIRC, the GS430 comes with a V8. Yeah, that's a 4.3L V8 vice V6 as was mentioned above. So what was this the older GS300/GS400 (3.0L I6/4.0L V8) or one of the new 2006 versions? If it was a GS400, they can haul bauls, even off the line and the Inline 6's are pretty sweet but they're also hamstrung by the automatic transmissions. Guys like that are jerks and need a beat down just to keep them humble. BOT - I really like having my car debadged and find it helpful in parking situations because there's less chance that someone will ticket a car that they can't identify without calling it in. Besides, it cleans up the rear of the car a lot and makes it very cleaning/detailing friendly. SBT - Pro amore Dei et patriam et populum - Link to comment Share on other sites More sharing options...
RockyMtnGT Posted July 18, 2005 Share Posted July 18, 2005 I had a little fun with a manual IS300 the other day. From a stop light... let's just say he gave up before I shifted to 2nd.... I had an easy car length by that time:cool: I'm sure he had no idea what just dusted him, until I politely showed him my rear:D Link to comment Share on other sites More sharing options...
gfxdave99 Posted July 18, 2005 Author Share Posted July 18, 2005 The 2006's have six speed autos now GS 430: - 4.3-liter (262 cubic inch), four-cam, four valves per cylinder 90° V8 engine. Certified Ultra-Low Emission Vehicle (U-LEV) - 300 hp @ 5,600 rpm, 325 lb-ft torque @ 3,400 rpm - Continuously Variable Valve Timing with intelligence (VVT-i) on intake valves - 0 to 60 in 5.7 seconds [1] - Top track speed: 149 mph (electronically limited) [1] - Aerodynamic drag coefficient: 0.27 - Six-speed sequential-shift automatic Electronically Controlled Transmission with intelligence (ECT-i) - Rear-wheel drive with standard Vehicle Dynamics Integrated Management (VDIM) [2] - Estimated fuel consumption: 18/25 mpg city/highway [3] - Electronic vehicle-speed-sensing, progressive power-assisted rack-and-pinion steering. Variable Gear-Ratio Steering (VGRS), 2.7-3.2 turns lock-to-lock - Front suspension: Independent, double-wishbone with coil springs, gas-pressurized shock absorbers and stabilizer bar - Rear suspension: Independent, multi-link with coil springs, gas-pressurized shock absorbers and stabilizer bar - 18 x 8.0-in alloy wheels with 245/40ZR18 tires [4] (18 x 8.0-in alloy wheels with available 245/40VR18 all-season run-flat tires [5]) GS 300: - 3.0-liter (183 cubic inch), four-cam, four valves per cylinder 60° direct injection V6 engine. Certified Ultra-Low Emission Vehicle (U-LEV) - 245 hp @ 6,200 rpm, 230 lb-ft torque @ 3,600 rpm - Dual Continuously Variable Valve Timing with intelligence (VVT-i) - 0 to 60 in 6.8 seconds (RWD) [1], 6.9 seconds (AWD) [1] - Top track speed: 143 mph (RWD) [1], 130 mph (AWD) [1] (electronically limited) - Aerodynamic drag coefficient: 0.27 - Six-speed sequential-shift automatic Electronically Controlled Transmission with intelligence (ECT-i) - Rear-wheel drive with standard Vehicle Stability Control (VSC) [6] (GS 300 RWD) - Full-time all-wheel drive, with standard Vehicle Stability Control (VSC) [6] (GS 300 AWD) - Estimated fuel consumption: 22/30 mpg city/highway (RWD) [3], 21/27 mpg city/highway (AWD) [3] - Electronic vehicle-speed-sensing, progressive power-assisted rack-and-pinion steering. 3.2 turns lock-to-lock (GS 300 RWD), 3.1 turns lock-to-lock (GS 300 AWD) - Front suspension: Independent double-wishbone with coil springs, gas-pressurized shock absorbers and stabilizer bar - Rear suspension: Independent multi-link with coil springs, gas-pressurized shock absorbers and stabilizer bar - 17 x 7.5-in alloy wheels with 225/50VR17 tires [4] (17 x 7.5-in alloy wheels with available 225/50VR17 all-season run-flat tires [5]) (GS 300 RWD) - 17 x 7.5-in alloy wheels with 225/50VR17 all-season run-flat tires [5] (GS 300 AWD) If everything seems under control, you're just not going fast enough. - Mario Andretti Link to comment Share on other sites More sharing options...
