S_S_H Posted July 21, 2012 Share Posted July 21, 2012 So I'm have some BC BR coilovers that i plan on installing soon. And I wanted to adjust my camber a little more than the stock camber bolt allows. Would I be ok with these? http://www.whiteline.com.au/product_detail4.php?part_number=KCA414&sans_vehicle=1 Or should I just go with the KCA399 bushings for the rear? Going to be running 18x7.5 +45 with 225/40 if it makes a difference. Link to comment Share on other sites More sharing options...
scoobyscoodle Posted July 21, 2012 Share Posted July 21, 2012 BC's have camber plates, why would you need different bolts? I'd just run the rear camber at whatever it comes out to, as you can't adjust it. You only need the rear camber bushings for fitment reasons (you should be fine), or for a specific alignment setup for a purpose build, where you need more in the rear than oem. Link to comment Share on other sites More sharing options...
